Thom_1991 Posted November 19, 2012 Author Report Share Posted November 19, 2012 Disconnected the sidestand switch, used a piece of wire to short the two wires from the loom together and it still cuts out. I've got the sidestand/turn signal relay box to check next but after that I'm fresh out of ideas. Anyone? Link to comment Share on other sites More sharing options...
jaycee Posted November 19, 2012 Report Share Posted November 19, 2012 Yes, you've bought a dud, I'll take it off your hands for £20. You HAVE checked through the loom like i suggested and checked that the relay sockets are also clean and corrosion free? Link to comment Share on other sites More sharing options...
Thom_1991 Posted November 19, 2012 Author Report Share Posted November 19, 2012 About to check the relay sockets. i just need to get it going again, get it home then its a full strip down and every bit of the electrical system wil lbe checked cleaned up and greased. Or i might just burn it. Link to comment Share on other sites More sharing options...
Thom_1991 Posted November 19, 2012 Author Report Share Posted November 19, 2012 Relay contacts clean. Link to comment Share on other sites More sharing options...
Thom_1991 Posted November 19, 2012 Author Report Share Posted November 19, 2012 I don't trust the diode test on my multimeter so I can I Just jump the relevant wires together to see if that's the issue? Link to comment Share on other sites More sharing options...
Thom_1991 Posted November 20, 2012 Author Report Share Posted November 20, 2012 Yes I can. And its the relay thats the problem. Yay. Link to comment Share on other sites More sharing options...
the bear Posted November 20, 2012 Report Share Posted November 20, 2012 i have a loom in the shed for one of those (fuel injected one?) if you fancy it like Link to comment Share on other sites More sharing options...
