hollo Posted November 3, 2012 Report Share Posted November 3, 2012 Hello , Can anyone help me ? . I've just bought an RG500 and it's fitted with a GSXR1000 complete front end ( forks , calipers and wheel ) . The problem that I have is the RG500 speedo is drive by a cable , but the GSXR wheel doesn't have any drive for the speedo . Given the choice I'd like to try and keep the clocks looking original , rather then fit a new digital dash . I've had a good look on the internet but cannot find anything that can help . Does any know of a way I can convert the standard RG500 speedo , so that it can be driven by a digital imput ? Thanks Mike . Link to comment Share on other sites More sharing options...
drunkn munky Posted November 4, 2012 Report Share Posted November 4, 2012 Have you looked at any of these? http://www.digital-speedos.co.uk/spare-parts--accesories-8-c.asp I used one to convert a mechanical drive to run a digital speedo but from what ive gathered you want to do the opposite? There maybe something there that will work for you though. Link to comment Share on other sites More sharing options...
marcaztls Posted November 4, 2012 Report Share Posted November 4, 2012 Useful link that, mucho gracias. Link to comment Share on other sites More sharing options...
hollo Posted November 4, 2012 Author Report Share Posted November 4, 2012 Thanks for the reply and the link ,I've already mailed that company but they couldn't help . Yes , I need the opposite , as I've the speedo which is cable driven, but no way of running a cable to it with the front wheel I now have . Option B is to fit a complete new digital set up , but given the choice I'd like to keep the clocks looking standard. Thanks again Mike . Link to comment Share on other sites More sharing options...
Jenny Pryde Posted November 4, 2012 Report Share Posted November 4, 2012 I would be inclined to sell the Thou front end, buy some standard RG forks and have Maxton convert to their GP20 cartridge spec. Fit a GSX 600 front wheel and you will retain the standard look of the RG but with much improved feel from the front end. And the forks will have the correct spring rate for the bike. And your speedo drive problem won't be much of a problem anymore... ...Ooooh, I've just found a lovely button...I could get a suit made to match it... Link to comment Share on other sites More sharing options...
VanWinkle Posted November 4, 2012 Report Share Posted November 4, 2012 does it have to be taken off the front spindle, no way of converting so that it can read off the front sprocket?. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted November 5, 2012 Report Share Posted November 5, 2012 If you want to keep the front end you'll need to change the wheel for one with a speedo drive. If your really lucky they'll be a suzuki wheel that will bolt in - try oldskool suzuki forum. If the speedo drive wheel alters the fork centers you might find the triple clamps from the same bike will work .... or not Link to comment Share on other sites More sharing options...
hollo Posted November 5, 2012 Author Report Share Posted November 5, 2012 Thanks for all the helpfull replies so far , but I don't want to go down the route of swapping the front end over again , even though I don't really want to , it looks like it will be easier to do down the new digital clocks route , unless somone knows of a way I can get the standard speedo to work without the standard cable drive. Thanks Mike . Link to comment Share on other sites More sharing options...
lorenzo Posted November 5, 2012 Report Share Posted November 5, 2012 Is there no way you could make room (by removing a spacer perhaps) in the front to fit a speedo drive? Link to comment Share on other sites More sharing options...
hollo Posted November 6, 2012 Author Report Share Posted November 6, 2012 Thanks for the suggestion lorenzo , I'm not not sure if that's possible , as I know that the spindle on the GSXR1000 is a lot thicker then the RG one. This was really the the reason for my post , just to ask if anyone has done anythong like this before. It's looking more likely that I'm going to go down the plan B route and have to fit digital clocks. Link to comment Share on other sites More sharing options...
