Flerbizky Posted October 21, 2012 Report Share Posted October 21, 2012 As the subject says - can I throw a 6" ZX7R rear wheel in a ZXR swingarm (K1)?. It's all about the size of the rear wheel, stupid I know, but the wider the better (-: Thanks Link to comment Share on other sites More sharing options...
hylar1000 Posted October 21, 2012 Report Share Posted October 21, 2012 it has been done but i don't know if it is a streight swap Link to comment Share on other sites More sharing options...
ZXRRDave Posted October 21, 2012 Report Share Posted October 21, 2012 P uses a different back brake setup, with a lug on the arm for the caliper hanger. I think there's a bit of work involved. Cuban pete has 7R wheels in one of his thunderbikes racers, so he may know. Link to comment Share on other sites More sharing options...
cuban pete Posted October 21, 2012 Report Share Posted October 21, 2012 As the subject says - can I throw a 6" ZX7R rear wheel in a ZXR swingarm (K1)?. It's all about the size of the rear wheel, stupid I know, but the wider the better (-: Thanks The rear will go in easily enough , but if you keep the stock rear caliper the rear disc offset is wrong . you will need a spacer to space the disc out the correct amount and some longer disc mounting bolts . other than that , use a 7r caliper and have a lug welded onto the swingarm . The wheels are pretty heavy . fine on a road bike , but on a track bike it tends to make it a bit of an effort hauling the bugger from side to side . it handles fine on a 190/55/17 Link to comment Share on other sites More sharing options...
lorenzo Posted October 22, 2012 Report Share Posted October 22, 2012 I'd be tempted to see what's needed to use a srad 750 wheel and brake caliper. Much lighter wheel, very similar looking caliper to the 7 r but mounts with a torque arm. I have no idea abut the spindle sizes etc, it'd probably need spacers making up and new bearings. Link to comment Share on other sites More sharing options...
tootall Posted October 22, 2012 Report Share Posted October 22, 2012 '04 zx10 wheel weighs fuck all and should fit easy enough. Link to comment Share on other sites More sharing options...
Flerbizky Posted October 22, 2012 Author Report Share Posted October 22, 2012 I'd be tempted to see what's needed to use a srad 750 wheel and brake caliper. Much lighter wheel, very similar looking caliper to the 7 r but mounts with a torque arm. I have no idea abut the spindle sizes etc, it'd probably need spacers making up and new bearings. No torque arm on this one - Which I recently picked up: http://pbmagforum.co.uk/index.php?showtopic=39017&st=0&p=743157 - and I just found a dirt cheap ZX7R rear, so I'm just going to shove it in there for now and see what happens (-: Link to comment Share on other sites More sharing options...
