My Next Nc30 Question
lorenzo
So, how long before you have to switch the fuel tap over to reserve usually? 85 miles seems a bit shit, doesn't it? It's about half a mile of urban roads, then onto the motorway for about 8 miles (often sat at a slightly brisk speed, but not 3 figures), then about 2 miles of urban stuff. All the urbanity is at about 30-40, a couple of sets of lights, but nothing involving filtering for miles on end or anything. What're your thoughts, people of PB land?
Can't remember an exact figure, however with K&N, race can, HRC ignition map and bigger jets... it's not a big figure.
Filled it up again, just short of 12 litres went in, I'd only done about 3 miles on the reserve. I guess it doesn't like being sat at 90 with a massively oversized rider causing a load of drag. Incidentally, 90 equates to about 9500 rpm, does that sound like stock gearing?
15/40 is stock
usually 1k per 10mph so probbaly about right...and to be fair, been a while since I did some mileage on mine but I'd want 100 miles before reserve.
OK then, here's the lesson: A modern fuel injected bike propels me to work faster, with more general lunacy and high jinks involved, and does about 30% better fuel economy. Put that in your pipe and smoke it, carb fans.
Hardly a fair comparison though, Loz? I'd argue that your NC is working a lot harder than your 675...
[Pedant] Work done= load carriedX distance travelled. So the NC30 won't be working harder, unless Loz has significantly increased the size of his packed lunch, to build up his winter fat layer.[/pedant] ;)
Maybe I used the wrong term. What I meant was the NC will be at larger throttle openings for a given acceleration compared to the 675, which is not having it's motor worked as hard to carry the...er...weight.
But loz you haven't looked at your carbs,, it could be a fair portion of your fuel is just washing away at your bores...
I have looked at them, but only from a distance of about 4 feet away, while they were in the bike.
Mine does 70 miles to reserve, at most. I've had an expensive summer.
Oh, that V4 growl.
<3
They are such lovely bikes, the '30's. small but perfectly formed. Like kylie's arse.
Ha, old and jaded....
I'm enjoying it, but bear in mind it's only a 15 min commute, maybe 25 at peak times. I'm much too big for it of course, but I don't mind. The fuel economy is a bit of a let down, but apart from that I'm enjoying the other aspects of it. Of course it's shit in comparison to my 675, that's really obvious, but it means I can go full whack at times, which I can't on the 675 so easily. The downside is that it lacks that searing turn of speed that you can get in the last 3000 revs on the 675, but I can live with it lower down, despite having to use the gears much more. I do miss the whole thing of checking it down 2 gears to overtake on the motorway and blasting past somebody with a ludicrous turn of speed, the occasional light print wheel as I hit a catseye. It's probably for the best that I'm not able to do this daily.... The chassis is great though, really confidence inspiring, irrespective of the conditions, which is why I bought it.
If you want a tidy set of black wheels, they feel like they're powder coated, let me know, go halves on tyres change costs and i'll get you a cuppa too..
So, it's thirstier than the 675 when it's going slowly, but the 675's thirstier going quickly. Tom's right (I can't believe I've just said that) though, despite probably going about 5 or 10mph slower on the motorway and certainly taking longer accelerating, the throttle openings on the NC30 are much wider than they are on the 675. I often skip up gears on the triumph, 1st, 2nd, then up into 5th or 6th once I've hit a sensible speed, which I could never do that on the 400 obviously, you just don't have that option. I'd have just assumed that because the 400 was a much smaller capacity that the economy would be at least similar to the 675, which does about 30% more mpg.
None!,,, but if you rode it sensibly it would return very economical fuel figures,
Meh I'm biased, I've had my nc35 since I was 18, it's heavy and underpowered by today's standards but nothing handles quite like it, it has character and is my mate, something that allot of modern bikes don't have
What's "very economical"? I know economy's not the reason anybody buys an nc30, but I chucked £13 worth in there today having covered 82 miles. This coming week I'm going to calm down a bit, at your request Beaner, and see if it matches up to moderate riding on the 675. I bet I don't get 135 miles from a tank, which is what the 675 does on steadier days, dropping to about 120 a tank when i'm being sillier. Even on track it's still turning perhaps 60 miles between fill ups.
It's the worst 4 stroke economy I've ever had from a bike, and possibly worse than my old TZR too, which again was a bit underpowered but a good laugh.
  • 3 weeks later...
I've been doing the maths here, it's about the same price to stick the bike in the back of my van and drive it there than to get the bike to do the journey with its own engine! Parking's not so easy as it costs £7 a day, so, as they say in the porn industry, fuck that.
