Pb Suspension Set Up Guide?
Deano_R1
Does anyone have the performance bike suspension set up guide for a 2009 R1? I've used them before on previous bikes and they have been brilliant, but I've been trying to contact PB and had no joy in getting any info?
Dean
Matt put these in the mag dated March 2011
Front 35mm static sag
Comp 5 turns from in
Rebound 5 turns from in
Rear 10mm static sag
10 mm more ride hight
Comp 8 turns from in
Rebound 8 turns from in
The rear was for a Ohlins TTX shock
These were the 'longtermer' settings after 13k
I had mine set up by Reactive Suspension earlier this year, if you can wait until October I'll PM the settings.
Found this on my hard drive, all it says is;
PB Suspension settings
Front
Preload 30mm static sag
Compression 5 clicks from in
Rebound 5 clicks from in
Rear
Preload 15mm static sag
High speed comp 8 clicks from in
Low speed comp 7 clicks from in
Rebound 2 clicks from in
