Yzf 750 Carbs
hylar1000
where if anywhere do the breather hoses between 1 +2 and 3+4 go? cheers
They sort of sit there doing not much except having bits of tube with a plastic bulby thing hanging off them. They don't link to anything. Odd, but true.
cheers, thats what I thought but I don't know the bike yet and some of the previous owners hve made some intresting decitions on where they put things
They're for vacum gauges
I don't think these bits are - they're t-shaped and link to blobby rubbery things.
Vacuum gauges are per carb, these are paired.
I think.
When I stripped my YZF750 carbs the floatbowl for number one was full of crud, the bowl for number two had less crud, three was only slightly cruddy and four was pristine, so only having a sidestand clearly has an effect. As before, two lines terminated in a blobby thing, it would probably feed into the airbox nowadays.
there not for balancing, my blooby thing has gone and as said i think now they would be part of a clean air system but as it was 1993 that crazieness had not yet started.
Bike is up and running nicely so cheers for your help fellas
