Paint - To Lacquer Or Not?
Jenny Pryde
Is it better to have lacquer applied? Or better to have none, so the top layer can be renovated if needs be?
Lots of new cars with solid colors are base coat then laquerd, gives the paint some `depth` (sp?)
Clear over base can be solid or metallic.
I had a X reg Ford Faeces in solid red that started to fade in a few places. Tried mopping it to no avail due to the clear. Grrr :eusa_wall:
Shined it up nice though...
as soon as you mop and see no base color on your mop it shows it been laquared.if this helps
the use of base coat color is to get a better final finish,as the lacquer is far finer to spray then solid color and hence lays and flows out better.
