crayons Posted July 2, 2012 Report Share Posted July 2, 2012 After spending an hour fiddling to go from bad brakes to none, I figured it was time to consult the forum experts. So what's your trick for filling & bleeding a rear brake with one of those HRC style tiny little hose reservoirs? Link to comment Share on other sites More sharing options...
radiobloke Posted July 2, 2012 Report Share Posted July 2, 2012 same as a normal res. did it on my zxr750 last week. took 15 mins. sounds like you've got a leak or something? Link to comment Share on other sites More sharing options...
theo Posted July 2, 2012 Report Share Posted July 2, 2012 Exactly the same as the normal reservoir. But Im removing the fuckin thing and returning to standard as I cut the bastard to long and it touches the underseat exhaust and has nearly melted the cap off. Link to comment Share on other sites More sharing options...
srad34 Posted July 2, 2012 Report Share Posted July 2, 2012 I use a syringe (One of the ones you get in a ink cartridge refill kit), keep topping the hose up whilst bleeding. These hoses tend to sweat, is it old or newly fitted, as per Radiosbloke, have you got a leak? Link to comment Share on other sites More sharing options...
crayons Posted July 2, 2012 Author Report Share Posted July 2, 2012 Aah thanks, the syringe idea got me thinking. I hooked up a regular plastic reservoir at the top of the tube and fitted a vaccuum pump to the nipple. Managed to flush the whole thing easily and job jobbed. It managed to hold a vaccuum so I hope that means seals are still good ? Link to comment Share on other sites More sharing options...
Fatbloke Posted July 9, 2012 Report Share Posted July 9, 2012 I bled mine backwards (no, not facing the wrong way looking at the shed wall) with a syringe Link to comment Share on other sites More sharing options...
