martzxr Posted July 1, 2012 Report Share Posted July 1, 2012 Right I've been given the task of putting a dr125 engine back together, as I didnt strip the engine my head is hurting wondering if I have the cam timing 180 degrees out With the piston at tdc and the timing mark lined up on the flywheel should the cam lobes be pointing up or down? The cam followers are above the cam on rockers Link to comment Share on other sites More sharing options...
martzxr Posted July 1, 2012 Author Report Share Posted July 1, 2012 Yea that's the thing, I'm presuming its tdc on compression, so looking at the geometry of the valve train I think the lobes should be pointing upwards. A look in a manual would be nice just to confirm it! Link to comment Share on other sites More sharing options...
cagimaha Posted July 3, 2012 Report Share Posted July 3, 2012 Is a DR125 not a single overhead cam using rockers to actuate the valves? If so, in order for the valves to close the cam lobes have to point downwards. It's probably worth trying to download a manual from the interweb. The engine was basically the same on the GN/GS/DR 125 range so any of the manuals should do. Link to comment Share on other sites More sharing options...
martzxr Posted July 3, 2012 Author Report Share Posted July 3, 2012 Yea lobes point down, engine up and running now, thanks for your input chaps. Link to comment Share on other sites More sharing options...
cagimaha Posted July 3, 2012 Report Share Posted July 3, 2012 No worries, glad you got it sorted. Link to comment Share on other sites More sharing options...
