rsv chris Posted July 1, 2012 Report Share Posted July 1, 2012 Hi guys and gals. Does anyone have a workshop procedure for the Topic title above? I'm needing to know if you can take the engine completely to pieces with the clutch basket still on. I can't get the bastard off and now the engine is out the bike. I basically want to strip the engine and gearbox to single components and sell it piece by piece on the bay. Cheers for any help. Link to comment Share on other sites More sharing options...
MonkeyJim Posted July 2, 2012 Report Share Posted July 2, 2012 Not sure about your k5, but I had the same problem with my old R1. Couldn't get the clutch basket ot [ it was a problem with the clutch that caused the engine failure] but managed to work around it. once I had split the crankcases I had sufficent room to get a wooden drift on the back of the clutch basket and drive it off the gearbox input shaft. the full thread is here http://pbmagforum.co...hl=houston&st=0 but you can skip to about page 4/5 where the engine strip down happens. I don't know if the suzuki engines is configured in the same way....? Link to comment Share on other sites More sharing options...
rsv chris Posted July 6, 2012 Author Report Share Posted July 6, 2012 Cheers Monkey. I read your thread and after seeing what you did, I replicated the procedure. Stripped it in 3 hours, and am now able to sell gearbox crank pistons and cases on the bay. I'm also a lot less affaraid of what's inside a gearbox. I.E sod all really. Link to comment Share on other sites More sharing options...
MonkeyJim Posted July 6, 2012 Report Share Posted July 6, 2012 Cool, glad you found it helpful Link to comment Share on other sites More sharing options...
Dan Posted July 6, 2012 Report Share Posted July 6, 2012 what other bits have you got left to sell? Link to comment Share on other sites More sharing options...
