speedy sie Posted June 19, 2012 Report Share Posted June 19, 2012 have a zx7r cam,... but want to know is it safe to pop in the old lathe and clean the cast makes of and clean the sides of the lobes??? Link to comment Share on other sites More sharing options...
Gregorious77 Posted June 19, 2012 Report Share Posted June 19, 2012 What for? Would it need to be balanced? Link to comment Share on other sites More sharing options...
speedy sie Posted June 19, 2012 Author Report Share Posted June 19, 2012 cams,not crank...just to help them throw oil better and clean the cast crappy surface of them as in polish then up ,have one kit cam and one very nice billet cam that would polish up with easy.. Link to comment Share on other sites More sharing options...
Superdunc Posted June 19, 2012 Report Share Posted June 19, 2012 Don't see any reason why you shouldn't do it. Link to comment Share on other sites More sharing options...
Gregorious77 Posted June 19, 2012 Report Share Posted June 19, 2012 will you finish it though?!?! Link to comment Share on other sites More sharing options...
hoona6 Posted June 19, 2012 Report Share Posted June 19, 2012 will you finish it though?!?! Touche Turtle*! *note I make no mention of Dum Dum Link to comment Share on other sites More sharing options...
bezzer Posted June 19, 2012 Report Share Posted June 19, 2012 Would have ...just to help them throw oil better and clean the cast crappy surface of them as in polish then up , They won't, smoother you make it the more the oil will "slip" off not get thrown as much as off a rougher surface. Link to comment Share on other sites More sharing options...
speedy sie Posted June 19, 2012 Author Report Share Posted June 19, 2012 the idea was to lighten the cams a bit,and remove all chance of brakage like polished rods and then pinned,but the cam will be criohardened afer the work done to it,the other cam is to this spec so carnt be that bad an idea?? Link to comment Share on other sites More sharing options...
rs250_steve Posted June 22, 2012 Report Share Posted June 22, 2012 i cant see the point to be honest. the weight you save wont be much, plus its such a small dia shaft it wont make a difference in terms of gyro and acceleration, strength....when was the last time your heard of a cam shaft snapping..... Link to comment Share on other sites More sharing options...
speedy sie Posted June 22, 2012 Author Report Share Posted June 22, 2012 oh...the tricks that went in to the old 750's are lost to most people today... lightened cams was a must back in the day,and im putting as much detail in to the engine that was in them back in the 90's..and just wanted to know if it was safe to day... Link to comment Share on other sites More sharing options...
rs250_steve Posted June 24, 2012 Report Share Posted June 24, 2012 Just go for it then. I can't see it making any difference, but you sie could find out otherwise! Link to comment Share on other sites More sharing options...
speedy sie Posted June 24, 2012 Author Report Share Posted June 24, 2012 had a good think and im getting the surface ground and then harded to match the billet inlet cam. Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2012 Report Share Posted June 24, 2012 Just fecking ride it. Link to comment Share on other sites More sharing options...
