MarkB Posted June 18, 2012 Report Share Posted June 18, 2012 Hi, i know this is a mod that some owners have already done so hopefully can offer some words of wisdom . Fitted an R6 throttle tube to my srad today and all is good as it is now only 1/4 turn but when i adjusted the freeplay, both cables are now at the top of their adjustment (they were about halfway with the srad throttle). Question is, is this due to the different throttle tube itself or are the cables due for replacement ? And, if i replace the cables do i use new srad ones or look at using R6 cables ?? Thanks in advance Link to comment Share on other sites More sharing options...
V6Jon Posted June 18, 2012 Report Share Posted June 18, 2012 Have wondered about don this to mine, do you recall exactly which R6 yours came from ? Link to comment Share on other sites More sharing options...
MarkB Posted June 18, 2012 Author Report Share Posted June 18, 2012 Off fleabay for £9 all in Listed as a` R6 throttle tube `99 - `02 5eb` Do it Link to comment Share on other sites More sharing options...
V6Jon Posted June 18, 2012 Report Share Posted June 18, 2012 Ta muchly ! Link to comment Share on other sites More sharing options...
ChefKoch_SRAD Posted June 19, 2012 Report Share Posted June 19, 2012 I needed also a shorter throttle cable. Because i use different carbs in my SRAD. I just soldered the ends by my self. It's very easy and cheap and you will have the perfect length. But do you have more infos and picutures of your R6 short stroke throttle modification? Does the throttle tube fit the original switch assy? Link to comment Share on other sites More sharing options...
MarkB Posted June 19, 2012 Author Report Share Posted June 19, 2012 R6 tube is same diameter as SRAD tube and it does fit the original switchgear. Just fits straight on. Easy mod to do. Link to comment Share on other sites More sharing options...
