mick750 Posted June 2, 2012 Report Share Posted June 2, 2012 y2k rsv mille on thursday evening riding home from work 5 mins in the engine died and wouldnt restart left it 2-3 mins started fine then 5 mins later it died again and wouldnt restart so parked it in a mates shed got a lift home i then went round later turned on the ignition (after putting it on a trickle charger) no fuel pump priming next day i went round it started fine just rode it home all ok apart from opening the throttle in 2nd it died then picked up straight away so any ideas ? Link to comment Share on other sites More sharing options...
mick750 Posted June 2, 2012 Author Report Share Posted June 2, 2012 is there any way to see if the pump is on its way out ? Link to comment Share on other sites More sharing options...
Cuzza Posted June 3, 2012 Report Share Posted June 3, 2012 Similar intermittent problem with my 00 RSV-R Mick.............the electrical connection for the fuel pump can, over time, become won and loose. Lift the seat and it's the white plug with 3 'prongs' I now have a cable tie around mine to prevent it from happening again......job jobbed ;-) HTH Jon Link to comment Share on other sites More sharing options...
Pierre Posted June 3, 2012 Report Share Posted June 3, 2012 Check what Cuzza says first, costs £0 , then millemilles breather pipes at £0 then fuel pump at £50 Have you done any servicing lately? My mate had 0 problems with his until he changed the air filter and then it started cutting out a few weeks later. He traced that back to the wires that Cuzza mentioned pulling apart slightly which must have happened when he wedged the tank up. Link to comment Share on other sites More sharing options...
mick750 Posted June 4, 2012 Author Report Share Posted June 4, 2012 right then ive just been out to have a look and cuzza it does seem a bit loose but not loose enough to cause any problems so started it up and while running disconnected the plug and engine dies so reconnect it and she fires back up again perfectly however i lety it get up to temperature and at 86 it died again and i seem to remember it was about that temp when it originally happened first so any more ideas ? Link to comment Share on other sites More sharing options...
Superdunc Posted June 4, 2012 Report Share Posted June 4, 2012 It's fooked. I'll give you 400 notes for it. Link to comment Share on other sites More sharing options...
levo Posted June 4, 2012 Report Share Posted June 4, 2012 £401..................... Link to comment Share on other sites More sharing options...
mick750 Posted June 4, 2012 Author Report Share Posted June 4, 2012 Sold to levo ! Link to comment Share on other sites More sharing options...
Superdunc Posted June 4, 2012 Report Share Posted June 4, 2012 Fancy making a profit Levo? £405, that's an easy 4quid... Link to comment Share on other sites More sharing options...
mick750 Posted June 5, 2012 Author Report Share Posted June 5, 2012 As in the petrol tank ? It has an aftermarket filler cap and one of the rivets has been drilled through Link to comment Share on other sites More sharing options...
mick750 Posted June 5, 2012 Author Report Share Posted June 5, 2012 Ok I'll do it when I get home from work later Link to comment Share on other sites More sharing options...
levo Posted June 5, 2012 Report Share Posted June 5, 2012 Cheque's in the post....... Link to comment Share on other sites More sharing options...
mick750 Posted June 13, 2012 Author Report Share Posted June 13, 2012 Well i started it up without the filler cap it ran for 30 seconds then died Now the fuel pump won't prime when I turn on the ignition Link to comment Share on other sites More sharing options...
mick750 Posted June 14, 2012 Author Report Share Posted June 14, 2012 gone to ks performance to get it sorted cause i dont really no much bout electrics ! Link to comment Share on other sites More sharing options...
mick750 Posted June 14, 2012 Author Report Share Posted June 14, 2012 Poss reg rec?? breaking down when it gets warm?? ye pretty much what i was thinking so we shall see ! Link to comment Share on other sites More sharing options...
mick750 Posted June 21, 2012 Author Report Share Posted June 21, 2012 Turns out it was the fuel pump was knackered and the relay was slightly corroded inside Thanks for everyones (apart from levo) help Link to comment Share on other sites More sharing options...
Gazza Posted June 21, 2012 Report Share Posted June 21, 2012 Turns out it was the fuel pump was knackered and the relay was slightly corroded inside Thanks for everyones (apart from levo) help So Mike was right, and you've got a £401.00 cheque from levo heading your way, not a bad days work. Link to comment Share on other sites More sharing options...
stretch Posted June 22, 2012 Report Share Posted June 22, 2012 Yeah! Keep the money and the bike! Link to comment Share on other sites More sharing options...
