silva511 Posted June 1, 2012 Report Share Posted June 1, 2012 Phatboy has kindly lent me his 7r so I can go with him to this year's TT, but at 84000miles the radiator is giving up the ghost. I've a leak which has failed to seal up with radweld. Leaving it standing still for a few minutes you can see the occasional drop of coolant leaking followed by the odd half-second high pressure blasts of coolant spraying itself all over the front tyre. This truly sucks! Is Gaffa tape going to have to be the only option since I leave in only a couple of days? Riding it normally is fine (London to Hull no problems), but it's a bit disconcerting if I'm on the mountain mile at 120mph banking it over. Anyone have any other solutions? Link to comment Share on other sites More sharing options...
jollygiant Posted June 1, 2012 Report Share Posted June 1, 2012 but it's a bit disconcerting if I'm on the mountain mile at 120mph banking it over. Anyone have any other solutions? Yes don't go over 119mph and all will be fine Link to comment Share on other sites More sharing options...
speedy sie Posted June 1, 2012 Report Share Posted June 1, 2012 devon ali repair will do it,just use it like epoxy filler ,used it in the parts and it is realy good stuff. http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&sqi=2&ved=0CGIQFjAA&url=http%3A%2F%2Fwww.devcon.com%2F&ei=nAHJT_bDLsGEOquiwf4P&usg=AFQjCNFsrHGcbQw-1D2omtgTGYfy5Gj_bg Link to comment Share on other sites More sharing options...
Superdunc Posted June 1, 2012 Report Share Posted June 1, 2012 Araldite. Drain the coolant, clean the area around the leak, then sand it to provide a key, then apply araldite, leave overnite, refill coolant. A bodge, which might last years, or could fail next week. You need a new rad ideally. Link to comment Share on other sites More sharing options...
porter_jamie Posted June 1, 2012 Report Share Posted June 1, 2012 Buy a new rad? How much is a spanker? Link to comment Share on other sites More sharing options...
silva511 Posted June 2, 2012 Author Report Share Posted June 2, 2012 Buy a new rad? How much is a spanker? Phatboy was curious as well to see how much. Official Kwacker dealer here in Hull quoted me £410. 2nd Hand off ebay is £150ish. Thanks for the suggestions, I'll see what I can do. Link to comment Share on other sites More sharing options...
silva511 Posted June 2, 2012 Author Report Share Posted June 2, 2012 Anyone used chemical* metal before? Edit:no idea why i put plastic instead of chemical. *facepalm* Link to comment Share on other sites More sharing options...
Benji Posted June 2, 2012 Report Share Posted June 2, 2012 Phatboy was curious as well to see how much. Official Kwacker dealer here in Hull quoted me £410. 2nd Hand off ebay is £150ish. Thanks for the suggestions, I'll see what I can do. Have you tried the breaker you have there in hull on hessle road, found them useful in the past. Link to comment Share on other sites More sharing options...
VanWinkle Posted June 2, 2012 Report Share Posted June 2, 2012 I have in the past used an egg to seal a leaking Rad in an emergency, held for about 6 months, personally I would be looking for a replacement so as not to spoil the party. Link to comment Share on other sites More sharing options...
cagimaha Posted June 2, 2012 Report Share Posted June 2, 2012 If it's just for the TT then I'd be looking at either Dunc or Sie's suggestion of Devcon or Araldite, I've used both before to repair engine casings or radiators which had split and each time the repair got me home. Indeed the starter clutch cover has had a bead of araldite keeping it oil tight for the last 6 months or so... Link to comment Share on other sites More sharing options...
porter_jamie Posted June 2, 2012 Report Share Posted June 2, 2012 theres one on the bay for 50 quid buy it now Link to comment Share on other sites More sharing options...
chrisexup Posted June 2, 2012 Report Share Posted June 2, 2012 i sealed a leaking exup rad with chemical metal, it's lasted for years with no probs. Link to comment Share on other sites More sharing options...
kwakbiker Posted June 3, 2012 Report Share Posted June 3, 2012 Liquid metal or k-seal? Or get the ali welding rods you use a blowtorch on, done this before after holing my last 9r's rad, worked fine and after a spray of black paint you couldnt tell Link to comment Share on other sites More sharing options...
silva511 Posted June 7, 2012 Author Report Share Posted June 7, 2012 Fixed! For now at least... 1st & 2nd attempt at Chemical Metalling it failed, as the hairline crack just pushed it's way through. 3rd time we used the rest of it and it managed to hold firm. Bit of gaffa tape as a secondary barrier to any spraying coolant and job jobbed! http://i241.photobuc...1/IMG_05681.jpg To make things more interesting once that was done, I lost my keys in a field in Glen Helen and got people searching for 3 hours *facepalm* Link to comment Share on other sites More sharing options...
