hoona6 Posted May 26, 2012 Report Share Posted May 26, 2012 Took the airbox off the Trumpet to change the plugs today and one of the intake trumpets has been damaged by a poorly seated retaining spring. New one ordered but my question is what is the glue-like substance securing them in place?? Any clues folks? Facebook piccy if you can see it... Link to comment Share on other sites More sharing options...
alexp5 Posted May 26, 2012 Report Share Posted May 26, 2012 Er, glue..? Link to comment Share on other sites More sharing options...
Gregorious77 Posted May 26, 2012 Report Share Posted May 26, 2012 probably some sort of 2 pack glue, I recon you will be ok using epoxy to stick it back on. Why are you taking your bike apart on the only 1 week window of decent weather for months!!??!!? Link to comment Share on other sites More sharing options...
hoona6 Posted May 26, 2012 Author Report Share Posted May 26, 2012 probably some sort of 2 pack glue, I recon you will be ok using epoxy to stick it back on. Why are you taking your bike apart on the only 1 week window of decent weather for months!!??!!? I'll nip down Halfords and pick some up. It's been off the road since last October and I'm finally getting mein arsch in gear. Shock off for a refresh, linkages greased, new plugs fitted, K&N fitted. New intake trumpet on order. Needs new pads, brake fluid, coolant, oil.... Fancy a stroll out one morning when it's back on it's feet? Link to comment Share on other sites More sharing options...
Gregorious77 Posted May 26, 2012 Report Share Posted May 26, 2012 yes!! scratchin weather it is! Link to comment Share on other sites More sharing options...
hoona6 Posted May 26, 2012 Author Report Share Posted May 26, 2012 yes!! scratchin weather it is! Brake pads ordered....inching closer! Link to comment Share on other sites More sharing options...
