drunkn munky Posted May 11, 2012 Report Share Posted May 11, 2012 I should start off that i dont own a RS250 but im fitting a RS HRC axle to a NC30 and am looking for options to lose as much weight as possible from the brake setup. Ive seen that breadline racing offer a alloy rear disc for the RS yet they dont mention the model/years that it fits, so are all RS250 rear discs the same weather it be single sided swinger or conventional setup? Link to alloy rear disc http://www.breadlineracing.com/rs250partsprice.html Pic of axle Pics fitted to the NC Next up is the caliper, would anyone happen to know mounting point holes distance on the RS caliper? Link to comment Share on other sites More sharing options...
RonniB Posted May 11, 2012 Report Share Posted May 11, 2012 Don't want to sound like a prick, but have you coppergreased the hub?? It should be fitted dry or you'll risk it sliding in the swingarm. I might know source for alloy disc to fit NC caliper, if the RS doesn't work out.. Ronni Link to comment Share on other sites More sharing options...
drunkn munky Posted May 11, 2012 Author Report Share Posted May 11, 2012 yeah i have copper greased it, thought id try and stop it getting in the siezed state it was in when i removed it but i now see your point. Id be interested in a alloy NC disc anyway if you know of one ronni Link to comment Share on other sites More sharing options...
wazrs257 Posted May 11, 2012 Report Share Posted May 11, 2012 There was a discussion about alloy rear discs a few weeks ago http://pbmagforum.co.uk/index.php?showtopic=35883 , the general consensus was they would warp too easily. What caliper will you be using? A 2 piston AP caliper (Or GBmoto copy) would save a bit of weight. Link to comment Share on other sites More sharing options...
drunkn munky Posted May 12, 2012 Author Report Share Posted May 12, 2012 Good read that cheers wazrs, I use the back brake enough to warrent having something usable there so looks like a standard disc is the way forward and maybe drill the holes bigger. The GBmoto caliper looks like a winner tho, cheers for bringing my attention to that Link to comment Share on other sites More sharing options...
