wazrs257 Posted May 7, 2012 Report Share Posted May 7, 2012 Can somebody that owns a radial caliper equiped GSXR take a measurement for me please? I need to know the distance between the centre-line of the caliper mounting bolts, to the centre of the disc. Cheers Link to comment Share on other sites More sharing options...
gixerboy1 Posted May 7, 2012 Report Share Posted May 7, 2012 Which plane are you looking at? The distance between the mounting holes is 108mm so the cl of the bolts to the centre of the disc is 54mm or is it the offset that you require? i.e the split line of the caliper to the centre of the bolts? Link to comment Share on other sites More sharing options...
wazrs257 Posted May 7, 2012 Author Report Share Posted May 7, 2012 Which plane are you looking at? The distance between the mounting holes is 108mm so the cl of the bolts to the centre of the disc is 54mm or is it the offset that you require? i.e the split line of the caliper to the centre of the bolts? Need the offset please. Link to comment Share on other sites More sharing options...
wazrs257 Posted May 10, 2012 Author Report Share Posted May 10, 2012 The answer, if anyone else needs it is 22mm. Link to comment Share on other sites More sharing options...
