Sean Posted April 29, 2012 Report Share Posted April 29, 2012 So my nice solid 350 tank i was once so proud about has bitten me in the ass. She's off to paint next week so i was cleaning out the tank to remove all the petrol gum before using the Por15 kit. And it started dripping, out with the wire brush and found these. Nothing to major. Now the solution can i weld them up if im super careful or am i better getting it brazed. Just concerned with how thin the metal it going to be around there, so im thinking it needs to be brazed. Link to comment Share on other sites More sharing options...
Conica Posted April 29, 2012 Report Share Posted April 29, 2012 Should get away with either process, Tig or Gas, But if it's that thin there then whats to say it won't hole in about 20 different places 5 minutes down the line? Is the root cause of these just down to corrosion? Edit:- I'd Tig it personally, But thats just my personal preference Link to comment Share on other sites More sharing options...
overload Posted April 30, 2012 Report Share Posted April 30, 2012 Mig wouldn't be a problem to use. Lowest setting and a quick fill on the holes should be enough and then a light grind down for a smooth finish. Link to comment Share on other sites More sharing options...
TriGGer Posted April 30, 2012 Report Share Posted April 30, 2012 If it's that thin due to corrosion in the tank ... silver solder all the way baby. Link to comment Share on other sites More sharing options...
