kaighn80 Posted April 6, 2012 Report Share Posted April 6, 2012 right i'm after some of that 2 part plastic repair resin, the type that comes in 2 tubes that are joined together and mixed in the nossle, anyone had any joy with it? how to's and where to buys if you please? Link to comment Share on other sites More sharing options...
moose_ Posted April 6, 2012 Report Share Posted April 6, 2012 I've never used the two part resin but I've used the Plastech repair which has a powder and liquid kit and found it dead easy to use for cracks etc. http://www.ebay.co.uk/itm/PLASTECH-PLASTIC-REPAIR-KIT-FAIRING-REPAIRS-/300689141193?pt=UK_Motorcycle_Parts&hash=item4602782dc9 Link to comment Share on other sites More sharing options...
blur1 Posted April 6, 2012 Report Share Posted April 6, 2012 i use 5 minute araldite. avaliable at all hardware stores and most car accessorie places. Link to comment Share on other sites More sharing options...
Erskimo Posted April 13, 2012 Report Share Posted April 13, 2012 5 min araldite is fine & or dandy, unless you need flexability then you need the 24 hour one, if i remember araldite was used to put planes together back in the day, there are many takes on 2 packs today that do a vast aray of tasks, they will only work if the areas are preped & clean.............had a GiSXeR '85 import back in the day got a new tyre fitted (a spacer was left out) after sitting in the low 200kphs i noticed it weaving more than normal, pull over to find the rear bearing has distroyed itself with some of the rim. new bearing set in the middle of the O/S hole with some loctite metal 2 pack wait half hour .........back to pinin it Link to comment Share on other sites More sharing options...
