andrews6179 Posted March 29, 2012 Report Share Posted March 29, 2012 been busy building a 748 over the winter all is ready but have a problem with the lights, the sidelights, dial lights and tail lights flash with the indicators, i have checked the earths and all is good, and found its the positive causing the problem, i have fitted a new flasher relay and has not worked am a bit stumped, i am waiting fr a new main ignition relay but cant find the fault and wondered if any1 can help. (i have non OE indicators but not led ones, i do have led rear stop lights but it still happens then this is disconnected, and battery is fully charged, and charging correctly) Link to comment Share on other sites More sharing options...
Tomfoolery Posted March 29, 2012 Report Share Posted March 29, 2012 Huh? Has the flasher relay been accidentally installed in the wrong place? Link to comment Share on other sites More sharing options...
andrews6179 Posted March 30, 2012 Author Report Share Posted March 30, 2012 according to the manual its correct and its the only 3 pin connector plug for that relay? Link to comment Share on other sites More sharing options...
