smobytoe Posted March 19, 2012 Report Share Posted March 19, 2012 Hello. I am generally clueless. Not just with things with two wheels but in life in general. Somehow i was given a radial master cylinder from a k7/8 gsxr 750. My question is…...will it actually help the braking on my 5jj R1? does anyone have a clue cos i don't. I could fit the fooker and find out with trial and error but i thought that someone would have some more knowledge of this sort of things with the ratios and all that stuff……..cheers rory. Link to comment Share on other sites More sharing options...
Thom_1991 Posted March 20, 2012 Report Share Posted March 20, 2012 Depends if it's intended for pumping two lots of four piston calipers on the gsxr then it should indeed be an improvement for the R1. Link to comment Share on other sites More sharing options...
lorenzo Posted March 20, 2012 Report Share Posted March 20, 2012 I've found that generally yamaha master cylinders tend to be quite good, less so suzukis. However, if the gsxr one is much newer, which it is, then it may well feel a but more responsive. In terms of ratios etc, it'll be ok, the piston sizes etc are all quite similar, but Suzuki tend to be a bit soft at the lever anyway. Link to comment Share on other sites More sharing options...
trackdaybob Posted March 20, 2012 Report Share Posted March 20, 2012 It should work pretty good if it's in good nick mate. Friend of mine has one fitted to his pi R6 and is very impressed with it. Link to comment Share on other sites More sharing options...
smobytoe Posted March 20, 2012 Author Report Share Posted March 20, 2012 Perfect!!! That's for the info boys! Bike gets mot'd the moro! Then I need to get the beast taxed and will get this biking year started, thank fuck! Hope you are feeling a bit better bob!! Link to comment Share on other sites More sharing options...
trackdaybob Posted March 20, 2012 Report Share Posted March 20, 2012 Aye I'm getting better each day thanks. Still hobbling around like an old man though. Link to comment Share on other sites More sharing options...
