Ducati Sprocket Carrier On Vfr400 Axle ?
Mohawk
Hi Guys,
Does anyone know if a Ducati rear sprocket carrier/cush drive assembly from a 748/916/996 etc will fit on the splines of a VFR400 axle ?
Or does anyone have both an VFR/RVF400 & a Ducati 748/916/996 etc which they could do a quick measure of for me ?
I know its pain to pull them apart, but if you have both, I quick OD check on the splined end of the shafts & a spline count would let me know if its worth getting one to check !
Or I could get lucky & have someone working on a pair of these ! Yeah I know whats the Odd's ?
Thanks
Chris W.
Never mind, found the bearing size info. Ducati internal is 35mm, VFR is 40mm, so to big for the Ducati carrier, bum :(
