Surflex Clutch In A Gsxr 1000 K3
Murky6
Hi there
Just need a little info I just changed the clutch In my bike I got the stack right but it needed one extra friction plate and one extra steel plate, but when I put it in gear with the lever all the way back to the bar the back wheel spins up as if the clutch is all the way out,
If anyone know how to sort it please help.
this may be stating the obvious but....
...have you tried removing the extra friction and steel plate and trying that?
Yeah I've tried that and it's about 5ish mm too short on the stack and the pressure plate doesn't even make contact with the plates then
