Gsxr1100/750 Calipers.
Bungle
Does any one know if the old slabbie 1100 & 750 brake discs & calipers are all the same?
If not can some one help & tell me the differences?
I have a set of slabbie calipers in the shed but do not have a clue which model they are from or which set of discs/forks they should be mated with.
Projects can be testing at times! :eusa_wall:
1100 Slabby discs are floating and 750 arent. 1100 are 310mm/750 are 300mm. 1100/750 may have different mounting bolt spacing but the caliper is the same IYSWIM?
Unfortunately no other calipers are a straight bolt on.
Also the same calipers were used on the GSXF Teapot but in black not gold.
Thank you. :icon_salut:
