Shot Blasting Aluminium
szrdave
I've got a slightly grotty (and blue) disc spider and manky master cylinder cap in aluminium I'd like to take back to bare metal and clean up for re-painting.
I also have access to a shot blaster that uses 316SS shot at work.
Would it be ok to use it to strip the above parts? Or is it likely to be too aggressive? confused.gif
Stainless shot on aluminium is a little aggressive i think. You may end up with dust.
Glass bead is the way to go. You'll get a nice satin finish and enough of a key for paint to stick. Use etch primer.
Crushed walnut shells is another alternative.
HTH.
I wonder if it'd be a good idea on the brake centre as the aluminium would perhaps get work hardened and become brittle?
Wouldn't of thought so... :eusa_think:
Soda blasting mebbe?
Waaaay too aggressive!!! The finished item will end up looking like grey charcoal! :lol:
Soda blasting is the way. :thumbsup:
Talking of blasting, I've got some Magnesium being Aquq-blasted as we speak. This is actually to clean up the sweated and rivetted on steel spoke ring on a set of wire hubs.
Anybody know a chemical way of colouring and protecting the raw mag when I get them back. :eusa_think::eusa_pray:
I've got some zinc paint coming, it's a nice satin grey colour and should weather a little in time, but it won't look perfect.
Magnesium needs to have a chromate appliied before painting. Chromate is the corrosion protection
http://www.mb-racingwheels.com/magnesium_protection.htm
You want mag to be Chromated as allready stated. The part will end up very dark grey in colour.
These peoplecan sort it for you and are fairly local. http://wdkmotorsport.com/contact.php
Speak to Ian or Simon.
I'm going to need to have my magnesium sprocket carrier machined down on the sprocket face. It's currently a light gold colour, I don't know what the coating is though.
I'll have to do something to protect this freshly machined face presumably? Any ideas what?
Ya see, it's all about the knowledge. I'd got it in my head that chromating was an electro process, probably 'cause of the old Electron name for mag alloy. Now a big bubbling vat of a witches brew is right up my street. Was worried about the steel and there are a couple of phosphor bronze bushes that I don't want to move. Ta :thumbsup:
And my friend, I'll be looking these guys up on Monday.
Don't think I need to stretch to 6kg of chemicals for a little job.
:icon_salut:
:icon_salut:
Simons on Holiday so speak to Ian.
I've had very good results with using aqua blasting that has a corrosion inhibitor in the media. I've done magnesium engine cases that way and other magnesium bike bits. They come up looking a satin bright colour. I've not applied any secondary coating and even after two years of use, they show no signs of corrosion. You could paint, of course. Don't ask me what the "corrosion inhibitor" is. It does seem to work, though.
In the end I couldn't be arsed with sanding or chemically removing the paint, so I gave it a go on the shot blaster.
Any ideas on the above at all folks? :)
you need to get it chromated. the gold colour you have on it is probably 'alocrom 1200'. it would be ok for a few weeks, but would soon fur up, and its not only the surface that corrodes, if left untreated microcracks can form and corrosion will burrow inside like woodworm. not that much of a problem on something like a cush drive, but on a wheel could prove catastrophic. :icon_pale:
