mick.r Posted January 9, 2012 Report Share Posted January 9, 2012 Hi Have a stainless end can (Arrow full system) on a ZX7R that has a few ugly dings in it. I can drill out the rivets and remove endcap and baffles ok. What I'm looking for, is does anyone know of a service similar to Dent Devil but for bikes???? Called local dent devil and they weren't interested because it was stainless !!! Anyone got any ideas of who to contact ??? Are there any clever sods on here that can sort it ??? regards Mick Link to comment Share on other sites More sharing options...
kaighn80 Posted January 9, 2012 Report Share Posted January 9, 2012 glue gun screws and dent puller you'll be fine! Link to comment Share on other sites More sharing options...
speedy sie Posted January 10, 2012 Report Share Posted January 10, 2012 yep we can do it,have done end cans before, stainless is my chosen material,can do a very good job,but in the end,the cost would be close to a new sleeve is it an oval Link to comment Share on other sites More sharing options...
mick.r Posted January 10, 2012 Author Report Share Posted January 10, 2012 Thanks for the reply Si. Yep its an oval. Sleeve only dimensions are 110mm wide x 137mm high x 500mm long. Rough costs for a new sleeve??? brushed satin finish. can strip and re-build it myself so just supply only. Many thanks Si Mick Link to comment Share on other sites More sharing options...
Leighio Posted January 10, 2012 Report Share Posted January 10, 2012 Had my end can apart this weekend to try and remove a dent, looks ok but would wish to replace it sighs new one. Are you able to provide new then So. Link to comment Share on other sites More sharing options...
mick.r Posted January 14, 2012 Author Report Share Posted January 14, 2012 Hey Si... just as Leighio said really Do you do them????? Cheers. Link to comment Share on other sites More sharing options...
speedy sie Posted January 14, 2012 Report Share Posted January 14, 2012 have load of ali ones...but no stanless Link to comment Share on other sites More sharing options...
750 Gixxer Posted January 14, 2012 Report Share Posted January 14, 2012 Maybe thise guys can help you. http://pjengineering.co.uk/index.php Link to comment Share on other sites More sharing options...
mick.r Posted January 15, 2012 Author Report Share Posted January 15, 2012 Cheers Gixxer !! Can't see what I'm after on there site so I'll give them a call Monday Si Could you make a stainless sleeve up ( man of your talents )....rough cost ?? cheers Link to comment Share on other sites More sharing options...
VanWinkle Posted January 15, 2012 Report Share Posted January 15, 2012 hold on its an oval can,right?. just whip the sleeve off and turn the dents to the inside bottom. Link to comment Share on other sites More sharing options...
speedy sie Posted January 15, 2012 Report Share Posted January 15, 2012 Cheers Gixxer !! Can't see what I'm after on there site so I'll give them a call Monday Si Could you make a stainless sleeve up ( man of your talents )....rough cost ?? cheers clould do...ill see if we have any thin guadge in the stores. Link to comment Share on other sites More sharing options...
mick.r Posted January 15, 2012 Author Report Share Posted January 15, 2012 Thought about turning it around. But for some reason Arrow put the welded seam on the inner side right down the middle, so it would look worse than the dents. Cheers Si. Link to comment Share on other sites More sharing options...
