Thom_1991 Posted December 27, 2011 Report Share Posted December 27, 2011 Does anyone know if the Fzr400rrsp's 17" 120 front wheel was the same on all Fzr 400 models or was it just the sp. I'm wanting to do a swap like this http://fazerowners.yuku.com/topic/31250#.TvoaONSDtyU to give me better tyre choice (120 instead of slightly odd 110) Also did the Fzr600 share the front wheel? Thankyou! Link to comment Share on other sites More sharing options...
lorenzo Posted December 27, 2011 Report Share Posted December 27, 2011 I'm sure evilchicken will be able to tell you, and maybe also clarify if the TRX uses the same wheel too; he had a pair of trx wheels off me for his fzr400. Link to comment Share on other sites More sharing options...
CMSMJ1 Posted December 28, 2011 Report Share Posted December 28, 2011 Kayla may well know too. She knows her Yams fo shizz Link to comment Share on other sites More sharing options...
Kayla Posted December 28, 2011 Report Share Posted December 28, 2011 Kayla may well know too. She knows her Yams fo shizz Word, innit The SP wheels use different bearings, or at least the fronts do (I think) so you need one from a 'normal' 3TJ/4DX. The TRX850 and FZR600R (4JH) wheels are the same as the 3TJ wheel, and use a 17mm bearing. Your discs will fit these wheels, and the wheel will fit straight in the Fazer forks and unless they've got a really narrow pitch (the 3TJ/TRX/4JH pitch is 200mm) or the hub width is different, everything should work ok All FZR400s are not the same. The early bikes (1WG) used a 3 x 17 wheel with a 15mm spindle. Clear? No? Jolly good If you get stuck, PM me if you want. I've got loads of different combinations of stuff here. Link to comment Share on other sites More sharing options...
Thom_1991 Posted December 28, 2011 Author Report Share Posted December 28, 2011 that link is to a thread where someone has used an sp wheel and it did bolt in and the discs were the right size. so if the sps wheel is unique i need an sp one no other Yamaha will do the job? Link to comment Share on other sites More sharing options...
Thom_1991 Posted December 28, 2011 Author Report Share Posted December 28, 2011 Or there isn't a difference.think i'll take a punt with one of the ones you suggested kayla then just reebay it or stick it on here if its wrong. cheers! Link to comment Share on other sites More sharing options...
Kayla Posted December 28, 2011 Report Share Posted December 28, 2011 Or there isn't a difference.think i'll take a punt with one of the ones you suggested kayla then just reebay it or stick it on here if its wrong. cheers! It'd be cheaper and easier to find a normal wheel than an SP one, they're pretty hard to find and tend to be hoarded by racers and if you're patient you should be able to find one for not much cash, I got one for £12 a few weeks ago. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted December 28, 2011 Report Share Posted December 28, 2011 The SP had different bearings because they used captive spacers. The standard 3TJ / 4DX wheels will fit in in exactly the same way if you use the spacer and a speedo drive. The TRX850 front Lawrance sold me dropped straight in when I had standard forks and also when I changed to SP units. The rear didn't fit but I only wanted the tyre. The FZR600R Foxeye uses the same wheels and to be honest you stand a better chance of finding those than a 3TJ for reasonable money. Link to comment Share on other sites More sharing options...
Thom_1991 Posted December 28, 2011 Author Report Share Posted December 28, 2011 Great thankyou all Link to comment Share on other sites More sharing options...
Thom_1991 Posted January 27, 2012 Author Report Share Posted January 27, 2012 3TJ Fzr 400 wheel does fit. 120 front when i need tyres, yay. Link to comment Share on other sites More sharing options...
