wil.co. Posted December 27, 2011 Report Share Posted December 27, 2011 Does anyone know of anyone in the UK or, well basically not Japan, that does the chain catchers used in endurance racing? failing that, if I were to get one fabricated, then drill into the swingarm and insert threads, how much, if at all, would this weaken the swingarm? it's on an SP-1 btw. Cheers ladies n gents! Link to comment Share on other sites More sharing options...
gixerboy1 Posted December 27, 2011 Report Share Posted December 27, 2011 I could machine one up for about £25 including anodising. Link to comment Share on other sites More sharing options...
SeXV Posted December 27, 2011 Report Share Posted December 27, 2011 I used the current thread for the hugger/chainguard on my ZX6R, and used a long alu spacer bolted down with a little pin bent to hold the chain, does the job. Wouldn't mind getting a trick looking one made up though. Link to comment Share on other sites More sharing options...
Cibbersicks Posted December 27, 2011 Report Share Posted December 27, 2011 Muwahaha... Sorry that doesn't help does it? I've used one OE fitment riv-nut designed for the original chain guard, then drilled and fitted another one a little further down. I'm lucky enough to own a pukka Japanese TSR job, TSR use these on their Suzuka spec endurance bikes. It won't weaken the swingarm as long as it's done correctly of course. I've seen small threaded bosses even welded into the swingarm for even more strength. Link to comment Share on other sites More sharing options...
Timbo S2 Posted December 27, 2011 Report Share Posted December 27, 2011 As its only for holding he chain whilst wheel changing, could one not be glued to the swingarm? Link to comment Share on other sites More sharing options...
Cibbersicks Posted December 27, 2011 Report Share Posted December 27, 2011 As its only for holding he chain whilst wheel changing, could one not be glued to the swingarm? Just for you Timbo, your very own! Link to comment Share on other sites More sharing options...
speedy sie Posted December 27, 2011 Report Share Posted December 27, 2011 http://www.google.co.uk/imgres?q=devcon+epoxy&um=1&hl=en&safe=off&biw=1024&bih=663&tbm=isch&tbnid=cHjXX8nJJYpKZM:&imgrefurl=http://www.ellsworth.com/display/productdetail.html%3Fproductid%3D2393&docid=R5XgxWdUnfBc9M&imgurl=http://www.ellsworth.com/imagelibrary/jpegs/100/LargePics/14278.jpg&w=375&h=500&ei=ORX6TuS9NsLv8AODmpzyAQ&zoom=1 should reed $12...not $200 dont knock the glue...lotus chassis have been glued for years...and this stuff id well it speaks for itself.. and a few bike company's have used glue on repair plates when frames have had been recalled for cracks... Link to comment Share on other sites More sharing options...
Timbo S2 Posted December 27, 2011 Report Share Posted December 27, 2011 Just for you Timbo, your very own! Mines got horns on... Link to comment Share on other sites More sharing options...
kaighn80 Posted December 27, 2011 Report Share Posted December 27, 2011 most pugeots are glues together, windscreens are glued in, its what you ask of the glue really so yes you could glue it in place using sikoflex (or as my dad calls it stick'o'flex) or something similar and i think you can get alloooooominium coloured one too. Link to comment Share on other sites More sharing options...
alexp5 Posted December 27, 2011 Report Share Posted December 27, 2011 Sikaflex 221. Top stuff Link to comment Share on other sites More sharing options...
speedy sie Posted December 27, 2011 Report Share Posted December 27, 2011 Sikaflex 221. Top stuff yep the stuff of legend...many a work mans boot nailed to the floor with that stuff Link to comment Share on other sites More sharing options...
Timbo S2 Posted December 27, 2011 Report Share Posted December 27, 2011 I played football with several guys who work at Lotus. A favourite joke was to use chassis glue to adhere fellow workers lunch boxes to workbenches, walls, ceilings etc. what a hoot. I'd never buy a lotus glued together by that lot... Link to comment Share on other sites More sharing options...
