Ascalon Posted December 19, 2011 Report Share Posted December 19, 2011 Well, I was doing a minor repair on the single unit on my ZXR-R and I managed to get some white overspray on the blue part of the tail unit. Would a T-Cut get rid of it? It's just painted firbe glrass, and I am not sure if there is even a lacquer coat on the blue bit. Any suggestions for removal of the overspray from other painted surfaces glady accepted. A Link to comment Share on other sites More sharing options...
Ascalon Posted December 19, 2011 Author Report Share Posted December 19, 2011 That's what I was hoping, but wasn't sure. Cheers mate, I'll try that. A Link to comment Share on other sites More sharing options...
sonic Posted December 19, 2011 Report Share Posted December 19, 2011 Clay bar from Halfrauds or similar will remove it. Link to comment Share on other sites More sharing options...
Ascalon Posted December 21, 2011 Author Report Share Posted December 21, 2011 Clay bar from Halfrauds or similar will remove it. That's that really fine polishing stuff, innit? Will check that out. Thanks A Link to comment Share on other sites More sharing options...
speedy sie Posted December 21, 2011 Report Share Posted December 21, 2011 no it look like blue tack if its the stuff i know,3m do it and this is the blue take stuff,use it ,,it will make you mouth drop,realy owsum stuff. ...use with water and just rub it over the over spray job done Link to comment Share on other sites More sharing options...
