bignige Posted December 5, 2011 Report Share Posted December 5, 2011 I'm looking for an alternative to these, mainly coz they are a little expensive and rust prone. http://www.davidsilverspares.co.uk/VFR800FIW-1998/part_23787/ I had thought that these would be perfect.. http://www.ebay.co.uk/itm/Mikalor-W4-Supra-W4-Clamps-40-43mm-FULL-304-Stainless-/320725623781?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aacbca3e5 But they don't seem able to take the torque of the standard Honda ones (no surprise there i suppose) Ideally i'd like a x2 40- 43 mm and 55- 59 for the end can. Best part of £50 for 3 clamps from 'onda for the VFR. Car type u clamps in these sizes? Your suggestions please? Link to comment Share on other sites More sharing options...
VanWinkle Posted December 5, 2011 Report Share Posted December 5, 2011 Ive used the stainless type similar to the ebay ones on a ZZR, they did the job and were still on the bike when i sold it on 2 years later. Link to comment Share on other sites More sharing options...
lorenzo Posted December 5, 2011 Report Share Posted December 5, 2011 I'd guess that they won't take the same torque as the pukka honda ones as they're stainless and hence have slightly different properties. That said, they state that the bolt's up to 8.8, which if that won't tighten up enough to stop and exhaust blowing then you've got a problem with your exhaust, not your clamp. Link to comment Share on other sites More sharing options...
bignige Posted December 5, 2011 Author Report Share Posted December 5, 2011 The standard 'onda clamps had a M8 bolt (if i remember right) the Ebay ones are M6. The standard mild steel? exhaust seemed to have more give than the Motad stainless one. The standard can end clamp has a 2 bolt fitting, i'm trying to do it on the cheap with a single bolt one. Me, heavy handed? Link to comment Share on other sites More sharing options...
Evilchicken0 Posted December 6, 2011 Report Share Posted December 6, 2011 Why not use some jointing paste just as seal then put the ebay clips on Link to comment Share on other sites More sharing options...
bignige Posted December 6, 2011 Author Report Share Posted December 6, 2011 I don't think paste is the solution, tho thanks for the advice. I've noticed it before on other stainless systems i've fitted, just less "give" in these systems. Might buy the Honda ones and get them zinc plated. Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 9, 2011 Report Share Posted December 9, 2011 um, what about mikalor clamps? very strong, and if you get the posh ones they are full stainless so its a clamp for life.... search for 'supra t w4' Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 9, 2011 Report Share Posted December 9, 2011 oh, just noticed the op pointed in the direction of mikalor clamps. do you have any idea how tight you can do them up??! they are bloody strong. Link to comment Share on other sites More sharing options...
Benji Posted December 10, 2011 Report Share Posted December 10, 2011 Got to say used Mikalor clamps several times on exhausts and never had one fail, they are close tolerance on size so measure first. Link to comment Share on other sites More sharing options...
bignige Posted December 10, 2011 Author Report Share Posted December 10, 2011 cheers for the replies. Link to comment Share on other sites More sharing options...
