Dan Posted February 12, 2012 Report Share Posted February 12, 2012 Dunno if its any help to any of you crm owners ..but i had a mk2 a while back and the std front brake caliper is excatly the same as on a drz400 its a straight swap. Link to comment Share on other sites More sharing options...
CRMotard Posted February 17, 2012 Author Report Share Posted February 17, 2012 After an exhaustive search the ebc disc is going in the bin. The bobbins are stuffed and are not replaceable on my model. I was really keen to try out the Chinese discs because on a few local forums they have been rated very high by people who track ride and have metalworking and disc brake experience in there line of work. So iv ordered a set of chinga discs haha Getting closer with the cylinder but have decided to oring the top. Ordered a grooving tool for the lathe from the uk. Should have that in 2 weeks Other good news, my shock has been fully rebuilt with new shims and spring. Will be fitting that tonight hopefully! Link to comment Share on other sites More sharing options...
CRMotard Posted February 17, 2012 Author Report Share Posted February 17, 2012 looks good!, re shimmed and re sprung color matched to the frame nicely! thanks to DMCC for his great work! just waiting on new bush for the top shock mount... should be here on tuesday Link to comment Share on other sites More sharing options...
CRMotard Posted February 22, 2012 Author Report Share Posted February 22, 2012 really happy with the new disc... just still waiting on the lathe tooling to turn up (cylinder o'ringing) and the shock top bush and then where ready to rock and roll Link to comment Share on other sites More sharing options...
peter187 Posted February 22, 2012 Report Share Posted February 22, 2012 Looking good mate. Link to comment Share on other sites More sharing options...
CRMotard Posted February 29, 2012 Author Report Share Posted February 29, 2012 big milestone today... been waiting for this day for a while Cylinder install time! BDC right at base of transfer ports exh port covered by skirt at TDC ktm piston and yz490 rod comes to the deck at TDC Link to comment Share on other sites More sharing options...
red Posted March 1, 2012 Report Share Posted March 1, 2012 looking good there! but you dont post picture on the underside if your cylinder i'm looking forward to the o'ringing process Link to comment Share on other sites More sharing options...
CRMotard Posted March 1, 2012 Author Report Share Posted March 1, 2012 you dont post picture on the underside if your cylinder if I showed you Id have to kill you Link to comment Share on other sites More sharing options...
CRMotard Posted March 2, 2012 Author Report Share Posted March 2, 2012 Just gota drop my base gasket off at a fab shop and get a 5mm spacer made on the plasma cutter... Pulled a few strings do should only set me back a few beers Starting to get pissed off with the parts shop... 3 days expected wait for a 4 dollar shock bush has turned into 3 weeks... Apparently it's landed in Australia and is now in transit Link to comment Share on other sites More sharing options...
peter187 Posted March 2, 2012 Report Share Posted March 2, 2012 It's a bit late now but have you looked at motosport for the oem parts you needed? They are quite cheap and fast, just sometimes you have to have a buddy in the states send it on for you. Link to comment Share on other sites More sharing options...
CRMotard Posted March 2, 2012 Author Report Share Posted March 2, 2012 yeah, I shopped around and got all the little OEM bits from BikeBandit in the states... was about half the price of the Australian prices and my mate has a mail forwarding box The CRM OEM bits I have to get from australia because the CRM was only released in Australia, the UK and Japan. had a little bit more progress today, installed the piston and cylinder with a temporary spacer, have to wait till next week to get the proper 5mm spacer plate plasma cut. -Just gota get some feeler guages so make sure the ring gap is right, -and need to buy some 10x1.25 threaded bar or bolts tommorow so that I can make some longer studs for the raised cylinder -but best of all, the 2005 CR250 pipe fits up to the CRM chassis very nicely, without any fowling issues on the engine frame or rear shock... even the CRM rubber exh mounts will work nicely. going down to the bike shop tomorrow to pick up my shock bush thank fuk its here Link to comment Share on other sites More sharing options...
CRMotard Posted March 9, 2012 Author Report Share Posted March 9, 2012 Finally, we've got a local Agip dealer who has a permanent shop front! THANKYOU APRILIA MELBOURNE CITY STORE!!!! I've stocked up on a few bottles of the Castor/Synthetic oil and their 70W-90 gear-synth oil performs well (friction drag) and is durable. Spacer Plate turned up! and installed Looking at getting Lozza to do me a 1.3mm squish and a 22 or 23cc head. things to do this weekend -Bolt up the exhaust -Get the servo motor functioning -Install a 13 degree flat curve on the ignition for first start up and piston heat cycling -set the PV curve then twiddle my thumbs untill head turns up Link to comment Share on other sites More sharing options...
wazrs257 Posted March 9, 2012 Report Share Posted March 9, 2012 Looking good mate. That barrel looks like its had a hard life, are they known for cracking? 2 out of the 3 top ends I have for my Rotax 257 have had to be welded, but its a known problem on them. Link to comment Share on other sites More sharing options...
CRMotard Posted March 9, 2012 Author Report Share Posted March 9, 2012 Looking good mate. That barrel looks like its had a hard life, are they known for cracking? 2 out of the 3 top ends I have for my Rotax 257 have had to be welded, but its a known problem on them. nah, its pretty much brand new. Lozza welded up the rear stud holes when we offset them for the CRM pattern, and had to add some extra meat. one day when Iv got some more time Ill die grind it back to look a bit nicer, but right now I just want to get her running Link to comment Share on other sites More sharing options...
CRMotard Posted March 18, 2012 Author Report Share Posted March 18, 2012 I think its time to start her up this week Link to comment Share on other sites More sharing options...
Alex_H Posted March 18, 2012 Report Share Posted March 18, 2012 I think its time to start her up this week Video that sir. Link to comment Share on other sites More sharing options...
CRMotard Posted March 18, 2012 Author Report Share Posted March 18, 2012 thats the plan might hit up that local kart track to do some heat cycling in the next few weeks too... for $30 bucks a day it sure is a safer/more legal way to heat cycle a race bike engine. Link to comment Share on other sites More sharing options...
CRMotard Posted March 21, 2012 Author Report Share Posted March 21, 2012 head turned up I managed to drop a head dowel down into the coolant jacket GRRR but a trusty zip tie and butchered fridge magnet came to the rescue installed with a home made copper head gasket compression feels really strong, can barely kick it over. plumbed but unfortunately I will have to undo all of the work Iv done tomorrow morning (asked for half a day off). Iv got two stripped threads in the top of the cylinder. Im going to have to tap them out to M10. then re-install the cylinder/exhaust/radiators/plumbing/head. then finally fill her with fuel/oil and kick her to life tomorrow arvo Link to comment Share on other sites More sharing options...
CRMotard Posted March 23, 2012 Author Report Share Posted March 23, 2012 Link to comment Share on other sites More sharing options...
jimjambandit Posted March 23, 2012 Report Share Posted March 23, 2012 I bet it smells as good as it looks. Fantastic. Link to comment Share on other sites More sharing options...
stuntmonkee Posted March 23, 2012 Report Share Posted March 23, 2012 FUCK YEAH!!! Link to comment Share on other sites More sharing options...
El Gringo Posted March 23, 2012 Report Share Posted March 23, 2012 Congrats Mate, that sounds and looks fantastic! Link to comment Share on other sites More sharing options...
wazrs257 Posted March 23, 2012 Report Share Posted March 23, 2012 Sweet! Was that the battery in the ruck-sack? Link to comment Share on other sites More sharing options...
CRMotard Posted March 23, 2012 Author Report Share Posted March 23, 2012 Yeah, for some reason my charging system died so I rigged up a couple torch batteries. Turned to be a blown fuse so I'll just put a bigger one in tommorrow and then take it out the road for some proper testing. Link to comment Share on other sites More sharing options...
peter187 Posted March 23, 2012 Report Share Posted March 23, 2012 Looks good mate. Link to comment Share on other sites More sharing options...
Alex_H Posted March 24, 2012 Report Share Posted March 24, 2012 Awesome mate sounds mint, bet its gonna go like hell too. Link to comment Share on other sites More sharing options...
CRMotard Posted March 30, 2012 Author Report Share Posted March 30, 2012 bahhh, still having servo motor dramas. Im thinking that there is a problem with the ignition as the servo is being spastic. turn the ignition on once and the servo spins to 2300mV (the max value on the curve, for servo cleaning), turn the ignition on a second time and the servo spins back to 400mV which is the min value on my curve start the bike up and it doesnt move at all. So Iv contacted ignitech to see if they have a solution or can repair the ignition if its damaged. Link to comment Share on other sites More sharing options...
CRMotard Posted April 8, 2012 Author Report Share Posted April 8, 2012 some testing clips from the weekend. went pretty well, and top end is very strong however the mid range is lacking big time due to the PV servo not working and the needle clip being too low making it too rich. but other than that it was very very fun! Ill get the jetting a bit closer, get the PV working then head out for one more test like this. then Ill dyno tune the bike, and then it'l be race ready the chicks dug it haha (my missus and her friend) and then I offered I offered a sacrifice to the two stroke gods Link to comment Share on other sites More sharing options...
2T Institue Posted April 8, 2012 Report Share Posted April 8, 2012 Holy Shit are they Evil Knevil signature series boots ! No wonder the girls went wild ! Link to comment Share on other sites More sharing options...
CRMotard Posted April 8, 2012 Author Report Share Posted April 8, 2012 The must have been because I reckon I cracked the Ton, on the bike today and felt pretty safe in my trusty "Kmart $8 Slip-ons" haha but thats what happens when you drive 30 minutes and realise when you get there that your boots arnt in the car. Link to comment Share on other sites More sharing options...
