lorenzo Posted August 31, 2011 Report Share Posted August 31, 2011 I may have just bought a fully cunted R1, an 06 5VY model. It's going to need a front wheel, fullt front fairing, clocks and more or less all the brackets that hold the fairings on. Just wondering like, how different are the fairings on the later bike, the 07-08 one? Obviously, they're slightly different shape, plus the engine's different etc, but does anybody know if the later fairing and/or tail will swap? What about the wheels? Clocks? Anything? Link to comment Share on other sites More sharing options...
Cibbersicks Posted August 31, 2011 Report Share Posted August 31, 2011 If I where you I'd be straight on the blower to Mark/Foggy to see what toys/spares they have knocking around at Phase One.... Not sure about interchangeability though. If you're struggling to find anything and you need to buy new, givvus a shout and I'll sort it out for you trade buddy. Link to comment Share on other sites More sharing options...
lorenzo Posted August 31, 2011 Author Report Share Posted August 31, 2011 Lovely, thanks Tom. I've a feeling all the little bits are going to be the trickiest to find. I think I've got a decent enough lead on the plastics and I'm wondering if I even need clocks*? *after seeing how much they go for 2nd hand... Link to comment Share on other sites More sharing options...
lorenzo Posted September 1, 2011 Author Report Share Posted September 1, 2011 I'm not even that fussed about road legal to be honest with you Josh, but yes, I'm not interested in a standard bike. Link to comment Share on other sites More sharing options...
r1bazza Posted September 1, 2011 Report Share Posted September 1, 2011 I think the later panels can 'be made' to fit with a little adjustment(or brute force and ignorance). I'm sure I've seen a 5vy R1 in a mag somewhere with a later fairing on it Link to comment Share on other sites More sharing options...
lorenzo Posted September 1, 2011 Author Report Share Posted September 1, 2011 There's already been a substantial bit of brute force applied to the bike via its immediate surroundings, I think I'm going to be getting a fair few brackets made up for it anyhow, so it's good to know that they'll sort of fit. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted September 1, 2011 Report Share Posted September 1, 2011 Think the wheels go straight in, discs as well. Clock bracket is different so may need swapping to the later one for bodywork to fit, but that should let you use later lights if you need them. Rest of the fairing mounts should be easy to fabricate. Probably got a Spondon subframe that would fit as the standard ones don't crash well if it's that bad. Could probably sort some rearsets or most of a set. Need to ask me when I'm in Somerset about clocks, may have a scruffy set, but from memory the bike will run alright with either set of clocks even though they're active. Probably know some more shit, tired just now. Won't be able to help until after Le Mans though. PM me at some point and I'll give U my mobby. Link to comment Share on other sites More sharing options...
ronenige Posted September 1, 2011 Report Share Posted September 1, 2011 Wheels from later ones fit but watch disc sizes , of the top of my head , 4 pots run 320 mm , 6 pots run 310 mm , if yours are 4 pot then fz1 discs fit and are sometimes a bit cheaper ( I got a 2000 mile old pair for my wets for £47 , kerfuckingching ! ). pm me your exact model code ( white sticker under seat summat like 5vy7 060 b ) and I'll sort you the exact parts pdf for you Link to comment Share on other sites More sharing options...
lorenzo Posted September 1, 2011 Author Report Share Posted September 1, 2011 Cheers fellers, this is just the into I'm after. I've got discs which are hopefully ok, but the rim of the front has a good sized ding in it. I've yet to collect the bike (tuesday) so i'll know a bit more about what it does and doesn't need by next week. Thanks once again. Link to comment Share on other sites More sharing options...
speedy sie Posted September 1, 2011 Report Share Posted September 1, 2011 ARSE 1........... Link to comment Share on other sites More sharing options...
ronenige Posted September 2, 2011 Report Share Posted September 2, 2011 what I can see of the front wheel looks like it may be fixable by a certain Dave East fella Link to comment Share on other sites More sharing options...
lorenzo Posted September 2, 2011 Author Report Share Posted September 2, 2011 Hmm, that's also pretty interesting to know. Once I've got the bike here I'll stick a few photos up, which hopefully will make the ones from the auction look a bit gloomy, and you'll be able to see that it is in fact in perfectly good condition.... Link to comment Share on other sites More sharing options...
r1bazza Posted September 2, 2011 Report Share Posted September 2, 2011 what I can see of the front wheel looks like it may be fixable by a certain Dave East fella I got my (quite badly)dinged front wheel repaired by Hagon,with a quick turnaround as well. Link to comment Share on other sites More sharing options...
lorenzo Posted September 2, 2011 Author Report Share Posted September 2, 2011 Yep, I know there's place out there you can sort things out, I guess it's a case of waiting until it turns up and seeing what can be done with it. I'd be very suprised if the forks can't be straightened as it's so slight but the wheel looks to have had a hard time of it. Link to comment Share on other sites More sharing options...
Annaz Posted September 3, 2011 Report Share Posted September 3, 2011 Wouldn't worry too much about clock brackets. You might be better off fitting a Koso dash or a race style digital jobberoony. Brackets can be made to make anything fit. Then you truly make it your own and in a budget too. Link to comment Share on other sites More sharing options...
lorenzo Posted September 6, 2011 Author Report Share Posted September 6, 2011 pm me your exact model code ( white sticker under seat summat like 5vy7 060 b ) and I'll sort you the exact parts pdf for you OK, according to the sticker on the little X shaped bit under the seat it's 5VYH 010 B: Does that mark it out as being an american model, I think it is, or are there other countries that have reflectors on the bottom of the forks? Link to comment Share on other sites More sharing options...
r1bazza Posted September 7, 2011 Report Share Posted September 7, 2011 Just put a post up on the yank based R1 forum to see if anyone there knows. Link to comment Share on other sites More sharing options...
ronenige Posted September 7, 2011 Report Share Posted September 7, 2011 OK, according to the sticker on the little X shaped bit under the seat it's 5VYH 010 B: Does that mark it out as being an american model, I think it is, or are there other countries that have reflectors on the bottom of the forks? There is no record of it on the Yamaha uk system , so it must be the one that was produced for the gay pride march in Brazil , these were only 2 speed and 17 hp , HTH or you could follow this link http://www.incolmotos-yamaha.com.co/site/LinkClick.aspx?fileticket=XiqaJ%2FUaxh4%3D&tabid=348 Link to comment Share on other sites More sharing options...
lorenzo Posted September 7, 2011 Author Report Share Posted September 7, 2011 Thanks for that Nige. In some ways though, it asks as many questions as it answers. For example, the clutch cover on mine is cracked at the bottom and is leaking, so I want a new one. The two diagrams, the one you sent me for the UK one, and this US one, they've got a different number for the cover. A squizz on ebay shows two designs for an 04-06 model, both 5vy etc. The one like mine (which there's only 1 of on UK ebay) has 5 flat bits leading up to the domed bit in the middle, like this, although that's got a damage repair in the same spot as mine's leaking. However, most of them on there have a domed bit with 6 circles on the side like this, and also a different oil filler cap too. Is the difference only cosmetic? Who knows.... Link to comment Share on other sites More sharing options...
Thom_1991 Posted September 11, 2011 Report Share Posted September 11, 2011 Silly man. You're a silly man. Not as silly as me bidding for a Zx10r radial m/c when there was the Zx6r one i've been told/found i actually wanted finishing tonight. Sigh. Zx10r Master cylinder anyone? Anyway like someone said race dash if a standard one is that expensive. Your bid for the R1 was made with the rebuild cost in mind, right Link to comment Share on other sites More sharing options...
lorenzo Posted September 20, 2011 Author Report Share Posted September 20, 2011 Ok, next compatibility question: my bike's an 05, will an 07/08 aftermarket shock fit and will the damping be ok? Link to comment Share on other sites More sharing options...
