Devon Posted August 27, 2011 Report Share Posted August 27, 2011 The Girlfriend has one of those honda pantheon maxiscooters for work but she keeps complaining that her phone battery is dying and she has no way of charging it. so is there any way of wiring in a phone charger to the battery? and how do I stop it from taking a charge when its not in use. I have a blackberry car charger hanging around if thats any good? Link to comment Share on other sites More sharing options...
Alex_H Posted August 27, 2011 Report Share Posted August 27, 2011 Buy this: http://www.ebay.co.uk/itm/Universal-Car-Cigarette-Lighter-Socket-12V-/140349727531?pt=UK_In_Car_Technology&hash=item20ad7ee32b Drill a hole somewhere under the seat maybe, mount it and hook it up the battery via a fuse. You can get fancy and fit a switch or even a relay to disconect it when the ign is off but I'd just go straight on the battery and remember to unplug whatevers plugged into it when not riding. Link to comment Share on other sites More sharing options...
Devon Posted August 27, 2011 Author Report Share Posted August 27, 2011 Cheers, I will take a look at that. Im thinking of fitting it the way you said and then if shes constantly draining the battery then I will put a relay in. Could you explain to me what relay I will need? and where to connect it. Link to comment Share on other sites More sharing options...
Alex_H Posted August 27, 2011 Report Share Posted August 27, 2011 Just a standard automotive relay, just search 12v 4 pin relay on ebay. Basically, the relay is just a switch, but instead of manually turning it on, 12v turns it on. You break the feed to your cigarette lighter socket with the switched side of the relay, and use a switched circuit on the bike to power the other side of the relay. Link to comment Share on other sites More sharing options...
Alex_H Posted August 27, 2011 Report Share Posted August 27, 2011 Link to comment Share on other sites More sharing options...
Devon Posted August 27, 2011 Author Report Share Posted August 27, 2011 do I need a normally open relay or a closed one? Oh and thankyou for the diagram Link to comment Share on other sites More sharing options...
Alex_H Posted August 27, 2011 Report Share Posted August 27, 2011 Normally open! If it were closed it'd be on all the time till you turned the bike on, then it'd be off lol Link to comment Share on other sites More sharing options...
Devon Posted August 27, 2011 Author Report Share Posted August 27, 2011 This one? http://www.ebay.co.uk/itm/12V-RELAY-4-PIN-AUTOMOTIVE-30AMP-RY1-CHANGEOVER-/270695680714?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f06b84aca Link to comment Share on other sites More sharing options...
Alex_H Posted August 27, 2011 Report Share Posted August 27, 2011 Perfect that mate Link to comment Share on other sites More sharing options...
Devon Posted August 27, 2011 Author Report Share Posted August 27, 2011 Thats great, thanks for your help.ordered it Link to comment Share on other sites More sharing options...
