711tattoo Posted August 15, 2011 Report Share Posted August 15, 2011 would the wheels of a k2 thou fit a 750 srad? i know ive asked about exhaust fitment on srads but what else can you swap direct from newer gsxrs ie rear sets Link to comment Share on other sites More sharing options...
YZ faybo Posted August 15, 2011 Report Share Posted August 15, 2011 You can with mod's but there front disk off set is different. loads of yanks offset the disks with spacers but I dont like the idea of that. Link to comment Share on other sites More sharing options...
lorenzo Posted August 15, 2011 Report Share Posted August 15, 2011 Wheels off a k3 thou are stupidly light. Dunno if they fit but I picked some round at triggers last week and I was shocked. Link to comment Share on other sites More sharing options...
speedy sie Posted August 15, 2011 Report Share Posted August 15, 2011 had k5 wheels on mine but they do break easy.......... Link to comment Share on other sites More sharing options...
YZ faybo Posted August 16, 2011 Report Share Posted August 16, 2011 http://www.gixxer.com/forums/showthread.php?t=55384 Join this site, loads of good info on swapping parts around. Just read the new starter post first before posting questions without using the search engine, some folk on there are quite fragile about "newbie" questions!!!! Link to comment Share on other sites More sharing options...
711tattoo Posted August 16, 2011 Author Report Share Posted August 16, 2011 cheers buddy also do any other year power comanders fit the inj srad? Link to comment Share on other sites More sharing options...
wazrs257 Posted August 18, 2011 Report Share Posted August 18, 2011 I fitted a 1000K3 front wheel to my 750L. Although the K3 discs had a zero off-set & my Ls discs were 10-15mm (cant remember off the top of my head) off-set, the K3 wheel was wider at the disc mounting faces, so ended up the same width accross the discs. According to a table of wheel fitments I have, the K1/2 & 3/4 front wheels are 128mm across the disc mounting faces, with zero off-set discs of 5mm thickness. HTH Link to comment Share on other sites More sharing options...
krazyk Posted August 19, 2011 Report Share Posted August 19, 2011 cheers buddy also do any other year power comanders fit the inj srad? the book says no one is Pc2 and one Pc3 Link to comment Share on other sites More sharing options...
