INGO Posted August 5, 2011 Report Share Posted August 5, 2011 Hi looking for help.I have an NC30 race bike and want to change the wheel to 17 instead of 18.Want to see is their much into it and what wheel fits.Thanks in advance. Link to comment Share on other sites More sharing options...
thefatman Posted August 5, 2011 Report Share Posted August 5, 2011 An RVF400 NC35 wheel goes straight on. That is the easiest option. You can modify a Honda Bros rear wheel to fit or the other better option is to machine the hub and add 4 wheel studs to fit a vfr750 5 spoke rear wheel which is a 5" rim so good for 160 tyres. Link to comment Share on other sites More sharing options...
deviant Posted August 5, 2011 Report Share Posted August 5, 2011 ISTR there's somewhere making pattern NC35 wheels for about £200 as well. One of the owners clubs? Link to comment Share on other sites More sharing options...
thefatman Posted August 5, 2011 Report Share Posted August 5, 2011 DK motorbikes do them, called Delkevic. Link to comment Share on other sites More sharing options...
INGO Posted August 6, 2011 Author Report Share Posted August 6, 2011 If i fit the NC35 wheel do i have to modify the suspension linkage or just change the wheel? Link to comment Share on other sites More sharing options...
nzknut Posted August 6, 2011 Report Share Posted August 6, 2011 If i fit the NC35 wheel do i have to modify the suspension linkage or just change the wheel? you will probably have to adjust the rear ride height to compensate for the smaller wheel. Link to comment Share on other sites More sharing options...
drunkn munky Posted August 6, 2011 Report Share Posted August 6, 2011 If i fit the NC35 wheel do i have to modify the suspension linkage or just change the wheel? Fit a NC35 linkage to compensate for the height difference, or weld up and re drill the mounting hole. I think you make it 8mm shorter to give the correct ride height. Dont be tempted to make it any shorter for more height as our run into clearance problems, if you want it higher then look at adjustable shocks. Link to comment Share on other sites More sharing options...
CMSMJ1 Posted August 6, 2011 Report Share Posted August 6, 2011 Dive onto 400greybike for some proper info but the guys are right. They are 400greybike crew too! Link to comment Share on other sites More sharing options...
landy63 Posted August 9, 2011 Report Share Posted August 9, 2011 Delvic (I think that's the name anyway) do a 17 incher, had one on my race bike with no adjustment Link to comment Share on other sites More sharing options...
INGO Posted August 9, 2011 Author Report Share Posted August 9, 2011 Thanks Guys all help is appricated. Link to comment Share on other sites More sharing options...
Leighio Posted August 18, 2011 Report Share Posted August 18, 2011 You might get more of a idea and help from the 400greybike forum and guy called Rick Oliver. Really helpful guy and used to sell kits for this type of conversion. Best of luck Link to comment Share on other sites More sharing options...
