ssray Posted August 1, 2011 Report Share Posted August 1, 2011 Where can you get off cuts of ali? i need 10mm thick and 50mm sq. so not worth ringing a big supplier. Cheers Ray Link to comment Share on other sites More sharing options...
porter_jamie Posted August 1, 2011 Report Share Posted August 1, 2011 smiths metals. wander in with some folding and they will let you root around the scrap bin Link to comment Share on other sites More sharing options...
wazrs257 Posted August 1, 2011 Report Share Posted August 1, 2011 E-bay's probably your best bet for bar ends/off-cuts. Or a kind soul from here may have an off-cut you can have. I've only got 8mm so can't help, sorry. Link to comment Share on other sites More sharing options...
ssray Posted August 1, 2011 Author Report Share Posted August 1, 2011 Cheers, i`m near stourbridge, so smiths a bit far Ray Link to comment Share on other sites More sharing options...
Kayla Posted August 1, 2011 Report Share Posted August 1, 2011 Is 12mm thick any good? Link to comment Share on other sites More sharing options...
desmojen Posted August 1, 2011 Report Share Posted August 1, 2011 There is an e bay seller called Forward Metals who is pretty good. I get little snippets from them quite frequently, they are cheap enough and will also cut things to size for you. Jen. Link to comment Share on other sites More sharing options...
lorenzo Posted August 1, 2011 Report Share Posted August 1, 2011 10mm thick? You building a really small battle tank? Link to comment Share on other sites More sharing options...
ssray Posted August 1, 2011 Author Report Share Posted August 1, 2011 12mm would do, it only neeeds to be 40mm sq. Ta Ray Link to comment Share on other sites More sharing options...
