chrisexup Posted July 19, 2011 Report Share Posted July 19, 2011 Can anyone help me find a disc? Or is there an online table of PCDs, offsets and other vital statistics of 320m discs available? i need a disc to fit a GSXR wheel that replaces the std flat 320mm 5 bolt disc with an offset version, initial measurements suggest 10mm but that could change depending on what forks/yokes i end up using.... i also have a wheel i need to find a 320mm disc for; it will need to have an inner diameter of 93mm, 6 bolt fixing, PCD of disc bolt holes 112mm. Link to comment Share on other sites More sharing options...
speedy sie Posted July 19, 2011 Report Share Posted July 19, 2011 proper disk spacers that go behind the disk for the suzuki wheel have them on mine 2.5mm,plus 10mm of set on the disk! each side. Link to comment Share on other sites More sharing options...
chrisexup Posted July 20, 2011 Author Report Share Posted July 20, 2011 Sie, 10mm offset sounds perfect! Which model of Suzuki is it for? disc spacers are no good for my application, i need to move the disc 10mm in! Link to comment Share on other sites More sharing options...
badgermilk Posted July 21, 2011 Report Share Posted July 21, 2011 have a look on the Braking website. From memory there is loads of information about offsets and swept areas etc. Link to comment Share on other sites More sharing options...
chrisexup Posted July 21, 2011 Author Report Share Posted July 21, 2011 Are you saying that you need the braking surface to be 10mm inboard of the carrier? yes, is that a bad idea? i am trying to avoid machining the hub or caliper. i also have a wheel i need to find a 320mm disc for; it will need to have an inner diameter of 93mm, 6 bolt fixing, PCD of disc bolt holes 112mm. i got the wheel today and measured it at 94mm id, 110mm PCD, so that's a Honda fitment Link to comment Share on other sites More sharing options...
chrisexup Posted July 21, 2011 Author Report Share Posted July 21, 2011 have a look on the Braking website. From memory there is loads of information about offsets and swept areas etc. thanks Badger, just started trawling through that, it may take a while to go through every bike they list though does anyone know of a disc to fit a GSXR1000K1/2 etc, but with an offset....? Outer Diameter 320,00 Inside Diameter 69,00 No. Of Holes 5,00 Bolt Pattern 91,00 Holes Diameter 10,50 Link to comment Share on other sites More sharing options...
speedy sie Posted July 21, 2011 Report Share Posted July 21, 2011 mine are ex world endurance disks of a srad,so you can try them to see if they can help. http://www.google.co.uk/url?sa=t&source=web&cd=1&sqi=2&ved=0CBcQFjAA&url=http%3A%2F%2Fwww.semc-brembo.com%2Fen%2Fcatalogue%2Fplaquettes.php&ei=I4IoTvCTM5GAhQfb0q3hCQ&usg=AFQjCNFJAzfmPwETDk-WuirkvuMsTeXvWw Link to comment Share on other sites More sharing options...
chrisexup Posted July 21, 2011 Author Report Share Posted July 21, 2011 Thanks for the offer Sie, that is very kind, but i haven't the budget for such exotica. i'm hoping now that an old exup front end will let me use the GSXR1000 c/f front wheel (without milling chunks out of it) until a cheap GSXR front end comes up. After reading that the K5/6 forks are good in this months PB i'm going to look out for a set whilst saving my pennies. Link to comment Share on other sites More sharing options...
chrisexup Posted July 21, 2011 Author Report Share Posted July 21, 2011 For future reference, brake disc dimensions are available here; Braking motomaster Grimeca Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 23, 2011 Report Share Posted July 23, 2011 I guess you've answerred your own question by looking for a Gix front end, but really you'd have needed the yokes to be wider so the forks would fit the wheel, if you see what I mean. Getting the whole front end will mean all you'll have to do is sort out the steering head stem and/or bearings Link to comment Share on other sites More sharing options...
