lewis203 Posted July 18, 2011 Report Share Posted July 18, 2011 I bought an 07 Z1000 for cheap but under about 20 mph when on the front brakes the front end sort of bobs up and down but there is no pulsing in the lever and the brakes appear normal and work well above 20mph. Does this sound like warped discs? Could it be anything else? Link to comment Share on other sites More sharing options...
chrisexup Posted July 18, 2011 Report Share Posted July 18, 2011 steering head/wheel bearings ? Link to comment Share on other sites More sharing options...
Alex_H Posted July 20, 2011 Report Share Posted July 20, 2011 Possibly: high area's on the discs, could sand fuck out of em with garnet paper or fit some sintered pads to try and sort it, or maybe seized up/full of crap bobbins, in which case brake cleaner and tooth brush Link to comment Share on other sites More sharing options...
lewis203 Posted July 28, 2011 Author Report Share Posted July 28, 2011 Thanks for the suggestions, gonna have a look at it soon and hopefully an easy fix. Link to comment Share on other sites More sharing options...
Alex_H Posted July 29, 2011 Report Share Posted July 29, 2011 Just so you know, it can happen when you've been riding then come to a junction and sit there with your front brake on. Makes hotspots on the discs and it's not ideal lol Link to comment Share on other sites More sharing options...
lewis203 Posted July 29, 2011 Author Report Share Posted July 29, 2011 Just so you know, it can happen when you've been riding then come to a junction and sit there with your front brake on. Makes hotspots on the discs and it's not ideal lol Previous owner said he thought it happened after he done a trackday and sat with the front brake on in the pits So looks like it's high spots then? Will try sanding them and see if that helps. Link to comment Share on other sites More sharing options...
Alex_H Posted July 29, 2011 Report Share Posted July 29, 2011 Previous owner said he thought it happened after he done a trackday and sat with the front brake on in the pits So looks like it's high spots then? Will try sanding them and see if that helps. Go for it mate, use garnet paper coz it doesnt come off the paper like wet n dry. Otherwise if you can get the disc off the bell then you could try surface grinding, dunno if it'd work on a bike disc though! Link to comment Share on other sites More sharing options...
gurninman Posted July 29, 2011 Report Share Posted July 29, 2011 give the disc buttons a look-over and free them off if they're seized Link to comment Share on other sites More sharing options...
