speedy sie Posted July 13, 2011 Report Share Posted July 13, 2011 well chap of loom and electrical knowing,need some info on a relay that i need,the spec if it available .. the tps needs to have a feed to see its there,as in cdi sends out 5v and needs a reply of the 5v feed to see its there. the info i need a relay that has to do this. join to wires together for a split second,when i switch the loom on.as in linking the two feeds to tell the tps its there,but i then need the rely to brake the contact,as the cdi knows its there,but i then need to brake the loop to get the tps to work, hope you can understand this,ANY help would be great so i have 12v feed available the cdi pumps out 5v Link to comment Share on other sites More sharing options...
speedy sie Posted July 14, 2011 Author Report Share Posted July 14, 2011 thanks very much Mike Link to comment Share on other sites More sharing options...
