srad34 Posted July 10, 2011 Report Share Posted July 10, 2011 Not the best start to the day.......cambelt related! Picture the scene... 7am Beautiful morning in Lincolnshire, new battery, fuelled up and up to temp by the time I get to my favourite roads, friends ZX9R and 07 Blade in the mirrors, loving the twisty stuff. Roll on 25mins, pulled up to a junction, down to one cylinder, aw bugger. Roadside strip much to my pals mirth this reveals knackered plug. So I managed to limp home and get the bodywork off..... Something just does not feel right. Here's why..... C'mon take a closer look... This was from the vertical cylinder, looks as if I had too much tension, fitted by yours truly a couple of weeks ago using the Facom tension tool, 500 odd miles done since. So with tears in my eyes, I stripped down the top end, inspected everything, but no damage found, good compression. Hmmm. Fitted a temp cambelt, reset the timing and put back together with new plugs and fuel pipe o rings. She started first time, dare I say it, actually running better than before. Lucky escape?? The weird thing is, does this put me off or send me running back to the Japside? No, not a bit Link to comment Share on other sites More sharing options...
fatfuk Posted July 10, 2011 Report Share Posted July 10, 2011 Yew lucky lucky lucky lucky lucky barsteward! Definetaly a bit of a knack fitting Ducati belts! Link to comment Share on other sites More sharing options...
jollygiant Posted July 10, 2011 Report Share Posted July 10, 2011 Definetaly a bit of a knack fitting Ducati belts! Which Srad34 has yet to learn Lucky you!! Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted July 10, 2011 Report Share Posted July 10, 2011 just saw this also on another forum, as was said there, perhaps the tensioner was wound round the wrong way? Link to comment Share on other sites More sharing options...
Bat Fastard Posted July 11, 2011 Report Share Posted July 11, 2011 just saw this also on another forum, as was said there, perhaps the tensioner was wound round the wrong way? +1 Yep, gotta check to make sure the tensioner pulley is adjusted correctly. If you do it the wrong way the belts can touch between the fixed roller and the adjuster roller. Not Good! Anyway, u is a lucky boy, lol. Link to comment Share on other sites More sharing options...
