lorenzo Posted December 22, 2008 Report Share Posted December 22, 2008 I'm after a rebuild kit for my new-but-horrible-looking-bought-off-ebay starter motor. I figure it's always going to be a bit tired as it's about 20 years old, but while it's out and I'm tinkering, I could fit a new set of bushes etc while I'm at it. But I've no idea where to start other than the explaination in the haynes of how to do it. Anybody? Link to comment Share on other sites More sharing options...
bezzer Posted December 26, 2008 Report Share Posted December 26, 2008 You wont find a "kit" for it, brushes are about the only thing you can actually replace the rest is a general clean including the commutator surface (where the brushes touch) you then start to get into rewind territory which you need a specialist for. Clean it all up and see if it works OK now before you start to mess with it. Link to comment Share on other sites More sharing options...
speedzephyr Posted December 26, 2008 Report Share Posted December 26, 2008 Yep, brushes and bearings are about all you'll replace in there. I always mark the case for proper reassembly, for lining up the bolts and to make sure I put the Caps on the correct ends (if you put it together backwards the motor spins backwards ) They usually have plain or needle roller bearings which I grease while its apart, and you will want to clean up the commutator with some light sandpapering or if it is grooved where the brushes were riding you can get it turned. After that you'll have a starter that's practically new! Oh I should add you dont need to replace the bearings unless they're crapped out. Good Luck! Link to comment Share on other sites More sharing options...
lorenzo Posted December 27, 2008 Author Report Share Posted December 27, 2008 Where do you get the new brushes from? Link to comment Share on other sites More sharing options...
billysbones Posted December 27, 2008 Report Share Posted December 27, 2008 Where do you get the new brushes from? There was someone on american ebay flogging starter motor rebuild kits. At least it came up on a search for my CBR600. Bear in mind though, that they tend to call their bikes "macho" names, like hurricane. they do do them though. Link to comment Share on other sites More sharing options...
lorenzo Posted December 27, 2008 Author Report Share Posted December 27, 2008 Coolio. I'd been trying searches for 'starter kit' etc, as soon as I did a search for brushes it came up with A: cleaning equipment B: starter motor bits. Ta muchly, I think, should the bits be available, I've all the info I need. Link to comment Share on other sites More sharing options...
