Annaz Posted June 17, 2011 Report Share Posted June 17, 2011 Thought I'd have a browse for a smaller front sprock (1 tooth down) so I looked on B&Cexpress and M&P but they only list standard ones. Can anyone recommend where to shop for the blarsted thing? Cheers A Link to comment Share on other sites More sharing options...
Lof Posted June 17, 2011 Report Share Posted June 17, 2011 If it's for a 2004-2006 R1 then i've got a set for sale in the pinboard section. Edit to add, I bought the kit from Markieboy off this forum. Tell him what you need and he'll supply. Link to comment Share on other sites More sharing options...
TKDMitch Posted June 17, 2011 Report Share Posted June 17, 2011 Fewer. Sorry, Hope you get one Mitch Link to comment Share on other sites More sharing options...
trackdaybob Posted June 17, 2011 Report Share Posted June 17, 2011 Phone B&C up. They're very helpful and I'd bet they'll have a front sprocket for you. If you look at the website the last 2 part numbers of the renthal sprocket are the number of teeth. Link to comment Share on other sites More sharing options...
lorenzo Posted June 17, 2011 Report Share Posted June 17, 2011 Fiddling the numbers on the b&c website like bob says, just change the bit with the teeth for one with the amount of teeth you want. Stick that number in the search bit and then you'll see if they do it. Link to comment Share on other sites More sharing options...
Annaz Posted June 18, 2011 Author Report Share Posted June 18, 2011 Cheers guys! I'm on the case now *Dons deerstalker and grabs the magnifying glass* Just changed the rear wheel bearing again, got 3500m out of this one, so I'm fitting a C3 bearing, which has smaller balls (like me!) and therefore they don't expand as much with the temperature. See how that goes. Link to comment Share on other sites More sharing options...
