Devon Posted June 12, 2011 Report Share Posted June 12, 2011 What do you guys reccomend for securing my tank to my bike, I wouldnt mind getting something made up, so its quick release but I didnt really want to to just use a nut and bolt Link to comment Share on other sites More sharing options...
thefatman Posted June 13, 2011 Report Share Posted June 13, 2011 A steel pin with a hole drilled through the end for an R clip would work well for that. Link to comment Share on other sites More sharing options...
kaighn80 Posted June 13, 2011 Report Share Posted June 13, 2011 yep needs a bit you can get hold of too so you can pull it out easier. Link to comment Share on other sites More sharing options...
Devon Posted June 13, 2011 Author Report Share Posted June 13, 2011 I remember seeing something like what I wanted on an endurance bike build on here a few years back I think it was an SRAD. I like the idea of the steel bar with an R clip on one end and a block on the other to pull it out, Now to find someone with a lathe that can do it for me. Link to comment Share on other sites More sharing options...
thefatman Posted June 13, 2011 Report Share Posted June 13, 2011 A nail with a penny washer on the end would work fine. http://www.screwfix.com/p/round-wire-bright-nails-steel-self-colour-5-60-x-125mm-1kg-pack/11036 Cut it to length and drill a hole for the r-clip, job done. Link to comment Share on other sites More sharing options...
BudgetBoy Posted June 13, 2011 Report Share Posted June 13, 2011 yeah just make a bolt type thing. But have no thread on it. Then drill hole and add a "R" clip to it. Then its a case of take out "R" clip, push bolt thorough a bit and pull it out. The bolt or square,circle bit you have on the end will enable you to get hold of the bolt and extract it. Link to comment Share on other sites More sharing options...
MonkeyJim Posted June 13, 2011 Report Share Posted June 13, 2011 where do you get one of those? I'd love to have one on the rear mount of the R1, but it would have to be longer and [probably] thinner than the one pictured above. it would save at least ooooh 5 seconds it takes to undo the standard bolt. i love QR stuff Link to comment Share on other sites More sharing options...
Devon Posted June 13, 2011 Author Report Share Posted June 13, 2011 So who can make one of these for me? I have the measurements, the bit that goes through the lugs is 5mm thick and 60mm long, this excludes the end bits like enough space for the r clip and the fancy bit on the other end Link to comment Share on other sites More sharing options...
chrisexup Posted June 13, 2011 Report Share Posted June 13, 2011 ahem! Link to comment Share on other sites More sharing options...
Cibbersicks Posted June 13, 2011 Report Share Posted June 13, 2011 Did this the other day on the CBR - I used the nurled end off an old die wrench - hollowed it out, tapped a thread in there and popped in a grub screw. Bought the ally bar from B&Q... Large R clip, lockwire and heatshrink and job done! Link to comment Share on other sites More sharing options...
Cibbersicks Posted June 13, 2011 Report Share Posted June 13, 2011 Oh and please ignore the rough ends of the nylon overbraid on the wiring loom, cable ties are now gone and replaced with proper cloth loom tape, much, much tidier... Link to comment Share on other sites More sharing options...
Devon Posted June 13, 2011 Author Report Share Posted June 13, 2011 I do like that, I will see what kayla says Link to comment Share on other sites More sharing options...
wazrs257 Posted June 13, 2011 Report Share Posted June 13, 2011 the bit that goes through the lugs is 5mm thick and 60mm long Should that be 6mm x 60mm mate? The bolt on mine is an M6. You could drill one end and fit a small diameter key-ring ring to pull it out with, then an R-clip on the other end. Link to comment Share on other sites More sharing options...
Devon Posted June 13, 2011 Author Report Share Posted June 13, 2011 Should that be 6mm x 60mm mate? The bolt on mine is an M6. You could drill one end and fit a small diameter key-ring ring to pull it out with, then an R-clip on the other end. oops after a recheck it is 6mm :/ that sounds a good idea, I will re-email her the right measurements. Link to comment Share on other sites More sharing options...
