R1GUY Posted June 2, 2011 Report Share Posted June 2, 2011 HI ALL, HAVE TRACKED DOWN A LOOM FROM A 1998 RRW BLADE TO GO ON MY BLADE POWERED ZXR400, THE ONLY PROBLEM BEING IS THAT THE BLADE ENGINE IN THE ZXR IS A 93 AND DID NOT HAVE A THROTTLE POSTION SENSOR ON THE CARBS, ANY IDEA IF IT WILL RUN WITHOUT ONE????? THANKS Link to comment Share on other sites More sharing options...
Kayla Posted June 3, 2011 Report Share Posted June 3, 2011 My TRX did and Thundercats will. You might need to wire the TPS to 0/12V to stop any tacho error codes though. Wiring the TPS to 0V on the TRX makes the cdi think it's at full throttle all the time. Link to comment Share on other sites More sharing options...
R1GUY Posted June 3, 2011 Author Report Share Posted June 3, 2011 thanks for that........... Link to comment Share on other sites More sharing options...
big nick Posted June 3, 2011 Report Share Posted June 3, 2011 Yeah you need to fool the ECU into thinking there is a TPS present. If not the negine will idle erratically in my experience. Link to comment Share on other sites More sharing options...
