badcherrys Posted June 1, 2011 Report Share Posted June 1, 2011 Hello everyone. I've got petrol seeping from the Milles petrol tank. It's seeping from the the plate that the tank brace is attached to. So what can I do? Can I weld it? Use some chemical metal? Or do I need another tank? Pics to follow........ Link to comment Share on other sites More sharing options...
badcherrys Posted June 1, 2011 Author Report Share Posted June 1, 2011 Link to comment Share on other sites More sharing options...
Cuzza Posted June 1, 2011 Report Share Posted June 1, 2011 Mate What year is it? Early 98 to 00 RSV tanks are metal, RSV-R from the same period and all 01 on models are plastic. Plastic ones are known to warp across the fuel pump mounting plates and can be made worse bu hamfisted tightening of pump mounting bolts - ask me how I know ;-( I have a spare 98 - 00 metal tank here looking for a new home. Good condition and in red. HTH Jon Link to comment Share on other sites More sharing options...
badcherrys Posted June 1, 2011 Author Report Share Posted June 1, 2011 Hi Jon. Yes it an 99 one. Metal tank. I might have to take you up on the offer. I was just wondering if it could be welded? Link to comment Share on other sites More sharing options...
Gregorious77 Posted June 1, 2011 Report Share Posted June 1, 2011 It probably could be welded depending on how bad the metal is in that area, might end up with a big old patch welded on. Link to comment Share on other sites More sharing options...
BudgetBoy Posted June 1, 2011 Report Share Posted June 1, 2011 It probably could be welded depending on how bad the metal is in that area, might end up with a big old patch welded on. THIS.^^ +1 I would also get the tank pressure tested to make sure its not still leaking. Link to comment Share on other sites More sharing options...
Cuzza Posted June 1, 2011 Report Share Posted June 1, 2011 Hi Jon. Yes it an 99 one. Metal tank. I might have to take you up on the offer. I was just wondering if it could be welded? PM Sent Link to comment Share on other sites More sharing options...
