Pete Posted December 19, 2008 Report Share Posted December 19, 2008 Mate of mines just bought a cbr600f 2001. In great nick but the rear shocks is as soft as buggery. PB did a list of suspension set-ups for all the bikes they tested, and had it on the old website but I can't find it now so any help would be appreciated. The guy he bought it off never changed his settings so I take it they're still stock. Both ends have got loads of adjustment left so your thoughts please ladies and gents. Pete Link to comment Share on other sites More sharing options...
blow_away Posted December 19, 2008 Report Share Posted December 19, 2008 I've got the setup guide as a PDF file - PM me your e-mail address and I'll send it to you Link to comment Share on other sites More sharing options...
matt_the_blat Posted December 19, 2008 Report Share Posted December 19, 2008 Which model is it? Is it carbed (with rounded air intakes and headlight) or fuel injection (more angular headlights and air intakes)? They were very similar bikes but the FI model got updated suspension so the settings are a bit different: 99/00 CBR600F-X/Y: Rear: Preload: position 3 Compression: half turn out from max Rebound: 1 turn out from max Front: Preload: 2 lines showing Compression: 1 turn out from max Rebound: 3/4 turn out from max 00/01 CBR600FS/Sport: Rear: Preload: position 6 out of 7 Compression: 1/2 turn out from full in Rebound: 1/2 turn out from full in Front: Preload: 1 line showing Compression: 3/4 turn out from full in Rebound: 1/2 turn out from full in I used to have an FX model - fabulous bike, still miss it. I used the PB settings which were good for my weight (~70kg in the nip) and made the bike feel much more composed. But bear in mind you really need to set the sag for your own weight. Also, when I sold mine with 35,000 miles on the clock the shock was shot and the rear tyre was wearing really quickly as a result, so a smart shiny new shock may be in order. Have fun! RFTR, Matt Link to comment Share on other sites More sharing options...
Pete Posted December 22, 2008 Author Report Share Posted December 22, 2008 Which model is it? Is it carbed (with rounded air intakes and headlight) or fuel injection (more angular headlights and air intakes)? They were very similar bikes but the FI model got updated suspension so the settings are a bit different: 99/00 CBR600F-X/Y: Rear: Preload: position 3 Compression: half turn out from max Rebound: 1 turn out from max Front: Preload: 2 lines showing Compression: 1 turn out from max Rebound: 3/4 turn out from max 00/01 CBR600FS/Sport: Rear: Preload: position 6 out of 7 Compression: 1/2 turn out from full in Rebound: 1/2 turn out from full in Front: Preload: 1 line showing Compression: 3/4 turn out from full in Rebound: 1/2 turn out from full in I used to have an FX model - fabulous bike, still miss it. I used the PB settings which were good for my weight (~70kg in the nip) and made the bike feel much more composed. But bear in mind you really need to set the sag for your own weight. Also, when I sold mine with 35,000 miles on the clock the shock was shot and the rear tyre was wearing really quickly as a result, so a smart shiny new shock may be in order. Have fun! RFTR, Matt Thanks for the help. He's got the FI model, I left the front end alone as it seems fairly good(but way off the above settings!!) The rear was increased preload to nr 5 (after we checked the sag with him on it- which got it to 30mm) and the compression 1 turn out from fully in. I'll bear in mind the above settings and once I've got him on a trackday or two we'll take another look at both ends. Thanks for your help again. Cheers, Pete Link to comment Share on other sites More sharing options...
