srad34 Posted May 22, 2011 Report Share Posted May 22, 2011 Hi all, I have just bought a 748 Biposto with Showa suspension. Can anyone recommend some decent suspension settings? I am 14 stone and will be using the bike for Twisty A and B roads around Lincolnshire. Any ideas would be apreciated chaps...... Link to comment Share on other sites More sharing options...
srad34 Posted May 24, 2011 Author Report Share Posted May 24, 2011 Head angle eccentric on the steeper setting, add a link to the chain and run the rear hub eccentric adjusted as far back as possible and add 15mm of rear ride height with the tie bar. And fitting a set of harris clip on bars in the oem clamps is also a good idea; they're a fair bit wider than the oem bars and put a lot more weight over the front and give you greater leverage. Thanks Mille mille, I will have a crack at this on the weekend. Hoepfully the new cans and stainless lines will be ready for fitting too! Cheers Link to comment Share on other sites More sharing options...
