pikeygit Posted May 19, 2011 Report Share Posted May 19, 2011 Hi I have an 2007 ZX10R, the pulley on the exhaust valve is badly corroded and fouls the cables causing the FI light to come on. phoned my local Kwak dealer and ching ching, £800 + the dreaded, because kawasaki don't list the pully as a seperate part and I need to buy the whole 'Y' Piece, well you can probably guess my response. I was a little annoyed to say the least so I wrote a complaint to Kawasaki Japan to make myself feel better, explaining how crap their dealers are because they won't raise an issue relating to the supply of some component parts, and that I won't be buying another Kwak. Anyway anyboby know where I can source this tuppeny bit part, before I resort to having to making my own. Link to comment Share on other sites More sharing options...
originalracingsnake Posted May 19, 2011 Report Share Posted May 19, 2011 Mr Pikey Git, meet Mr Akropovic. Mr Akropovic, Pikey Git. Link to comment Share on other sites More sharing options...
Lobo Posted May 20, 2011 Report Share Posted May 20, 2011 There's one on ebay at £150 buy it now http://cgi.ebay.co.uk/kawasaki-zx10r-exhau...56#ht_500wt_793 Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted May 20, 2011 Report Share Posted May 20, 2011 Akra used to do a small 'buffer' that fixes onto the pulleys servo to trick the pulley into thinking the cables are attached when a full systems been fitted.used to be available separately for under £30 I think.The valve is left sprung fully open I think?worth a try!!Be carefully undoing the pulley servo wheel as the cogs inside are plastic and break easily-ie hold the wheel securely when removing centrebolt Link to comment Share on other sites More sharing options...
