BUSABOY Posted May 11, 2011 Report Share Posted May 11, 2011 Can anyone recomend a matt black paint for painting calipers. Is hamerite high temperature paint any good? Cheers. Link to comment Share on other sites More sharing options...
BudgetBoy Posted May 11, 2011 Report Share Posted May 11, 2011 Can anyone recomend a matt black paint for painting calipers. Is hamerite high temperature paint any good? Cheers. I painted mine with High temp paint and then put lacquer over them.The high temp paint is a matt finish. I have my rear caliper in the matt stage atm.. i will grab a photo to show you what it look like. brb Ok back here you go this is just the high temp paint. To be honest IMO Hammerite would be ok. I am led to believe that calipers from the factory are not painted with anything special.I'm sure it is normal paint. As long as you do the prep work to the caliper i cannot see any problems. Link to comment Share on other sites More sharing options...
BUSABOY Posted May 12, 2011 Author Report Share Posted May 12, 2011 I painted mine with High temp paint and then put lacquer over them.The high temp paint is a matt finish. I have my rear caliper in the matt stage atm.. i will grab a photo to show you what it look like. brb Ok back here you go this is just the high temp paint. To be honest IMO Hammerite would be ok. I am led to believe that calipers from the factory are not painted with anything special.I'm sure it is normal paint. As long as you do the prep work to the caliper i cannot see any problems. Thanks for the photo's, I might go with the high temp Hammerite, the paint you have used is more charcoal than a deep black, I would want to try something with a darker pigment. A lacquer would give them a darker final finish? Regards Link to comment Share on other sites More sharing options...
BudgetBoy Posted May 12, 2011 Report Share Posted May 12, 2011 Thanks for the photo's, I might go with the high temp Hammerite, the paint you have used is more charcoal than a deep black, I would want to try something with a darker pigment. A lacquer would give them a darker final finish? Regards No probs mate. Hammerite should be fine. I only used this paint as its HTP ,but i will be putting lacquer over it so it dont matter. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted May 17, 2011 Report Share Posted May 17, 2011 PJ1 engine enamel ??? Comes in matt, satin and gloss, it's easy to use. I did a radiator in it with a light gloss over a full matt coat to give a this effect What ever you use you'd probably need to cure it. Paint the caliper and let it dry then hang it in an oven from cold, use a low heat and allow it to cool then a medium heat. Link to comment Share on other sites More sharing options...
kaighn80 Posted May 18, 2011 Report Share Posted May 18, 2011 i did my engine in satin black engine enamel and its come out really nice, cant put that in the oven though so i started the bike let her get hot enough to start the fan then turned it off, if your brakes are getting hot enough to worry about using htp would there be something wrong? my brakes have only ever got that hot on an old mini that had drum brakes all round, did give me a few giggles though, was an episode where every one got a bit concerned after i'd turned up at work and the front brakes had caught fire. Link to comment Share on other sites More sharing options...
