stuntmonkee Posted May 10, 2011 Report Share Posted May 10, 2011 Hi people, I'm looking for the measurement from the swingarm pivot point to the rear wheel spindle on a 2007 R1 (or other years that have the 'underslung brace). If someone would be kind enough Thanks in advance Link to comment Share on other sites More sharing options...
TheGoat Posted May 10, 2011 Report Share Posted May 10, 2011 It'll try and sort you out when i get home. Does it matter that the spindle will be in a slightly different position on each bike? Due to varying chain wear etc. Link to comment Share on other sites More sharing options...
stuntmonkee Posted May 10, 2011 Author Report Share Posted May 10, 2011 Nope it'll be close enough, but if you could try measuring the adjust slot aswell I can then work out the max vs min overall length. Cheers Link to comment Share on other sites More sharing options...
TheGoat Posted May 10, 2011 Report Share Posted May 10, 2011 Nope it'll be close enough, but if you could try measuring the adjust slot aswell I can then work out the max vs min overall length. Cheers I'll see what i can do. What are you up to anyway Link to comment Share on other sites More sharing options...
stuntmonkee Posted May 10, 2011 Author Report Share Posted May 10, 2011 I'd tell you but I'd have to kill you Link to comment Share on other sites More sharing options...
levo Posted May 10, 2011 Report Share Posted May 10, 2011 Having a guess 550mm........? Link to comment Share on other sites More sharing options...
TheGoat Posted May 10, 2011 Report Share Posted May 10, 2011 i've got 600mm for the pivot to the spindle, and 65mm for the adjuster slot. Give or take a few. Link to comment Share on other sites More sharing options...
stuntmonkee Posted May 10, 2011 Author Report Share Posted May 10, 2011 Thank you V much Link to comment Share on other sites More sharing options...
